Progressive monoshock and 26" wheel - Road Glide Forums
post #1 of 19 (permalink) Old 07-14-2014, 03:14 PM Thread Starter
1CoolZ71's Avatar
Progressive monotubes and 26" wheel
I have a 26" wheel with a wrap fender on my 2013 RGC.
There is only 3" from the fender to the bottom of the triple tree.
When I hit a big bump the fender hits the tree.
How did you guys limit the travel when using monotubes?
Do I just add more clips or put a rubber bumper on the sliders?
Using the Kewl Metal 40 degree rake kit
2019 Road Glide Special in Grey Denim Stage II 114 CI
800 watt stereo, Ciro Latitude tail light
King pak with smoked lights and heated backrest
1CoolZ71 is offline
post #2 of 19 (permalink) Old 07-14-2014, 03:45 PM
Shark of the Month August 13
SIC_26's Avatar
Yes, u need to install some sort of travel limiter on the dampening rod......same concept as with a conventional oil/spring set up.
Did the kewl metal extensions accept the monotubes?
Sent from Motorcycle.com App
SIC_26 is offline
post #3 of 19 (permalink) Old 07-14-2014, 03:51 PM Thread Starter
1CoolZ71's Avatar
You can use the monotubes, just don't use the top bolt or it will hit the neck and limit turning radius.
Kewl pinches the tube itself so the top bolt isn't needed.
1CoolZ71 is offline
post #4 of 19 (permalink) Old 07-14-2014, 04:30 PM
SIC_26's Avatar
The lower tree clamps the tube and the fork leg extension threads into the upper tree.....that's how it is on most aftermarket trees.
I only ask cuz not all manufactures fork leg extensions are threaded to accept the the "tip" of the monotubes once the cap is removed. I've never messed with the Kewl metal stuff but love to learn new stuff
But to answer your original question, an internal travel limiter is what's needed. You can go to the hardware store and get what you need or you can call Paul @ Native and he'll get you setup up with the material.
SIC_26 is offline
post #5 of 19 (permalink) Old 07-14-2014, 04:38 PM Thread Starter
1CoolZ71's Avatar
Are there instructions somewhere on what is needed and how to do it?
I can fabricate most things but need guidance on what to make and where to put it.
1CoolZ71 is offline
post #6 of 19 (permalink) Old 07-14-2014, 04:46 PM Thread Starter
1CoolZ71's Avatar
I've been searching this site and it looks like some people have tried to put the stock spring on the bottom of the monotube in addition to the one that Progressive provides.
Has anyone actually tried it and does it work?
1CoolZ71 is offline
post #7 of 19 (permalink) Old 07-14-2014, 05:00 PM
SIC_26's Avatar
Remove front wheel/fender
Remove fork legs, remove internals, reinstall fork legs
Install axle (no wheel) to tie the two legs together and give you something to push on
Measure (fender mount to a fix object) this will give you your fully extended length
Push front end up (collapsed) measure the same two points again, this will give you your bottomed out measurement
Reinstall you front wheel and fender
Push front end up til your fender makes contact with lower tree/fairing and measure again
****numbers are just for reference only****
20" from point A-B extended
16" front point A-B collapsed
4" of total travel
If your fender hits your lower tree at 19" then you would need a 1" travel limiter, I always add 1/8"-3/16" just for safety sake
Cut your travel limiter to length
Remove wheel, fender, forks etc
Install travel limiters on the the dampening rod of the monotubes...DO BOTH SIDES
Reassemble fork legs
Reinstall fork legs into triple trees
Reinstall front wheel, brake fender etc
Enjoy riding worry free
That's a lot to type on my phone LOL but I thing you get the general idea
SIC_26 is offline
post #8 of 19 (permalink) Old 07-14-2014, 05:02 PM
SIC_26's Avatar
When installed there's no worries....here's mine bottomed out (mock up) fender to lower tree clearance
SIC_26 is offline
post #9 of 19 (permalink) Old 07-14-2014, 05:06 PM Thread Starter
1CoolZ71's Avatar
Thanks for the help!
1CoolZ71 is offline
post #10 of 19 (permalink) Old 07-14-2014, 05:10 PM
SIC_26's Avatar
No worries, if you have any questions just ask
SIC_26 is offline
21" 23" or 26" Wheel rconnor Wheels and Tires 11 07-12-2015 10:03 PM
Monoshock Noise? Hunter 1 Suspensions 7 08-22-2013 03:40 PM
Progressive Monoshock 1BigGuy Suspensions 10 10-12-2011 09:20 PM
23" / 26" Wheel Question LuckySOT Aftermarket Accessories 7 02-09-2011 05:23 PM
