Fork Oil Change - Couple Questions - Road Glide Forums
post #1 of 7 (permalink) Old 07-21-2014, 04:10 PM Thread Starter
Just drained fork oil on 13' RGC. Manual calls for 10.7 ounces. I only got about 9.5 oz. out of the right leg and maybe just shy of 11 oz on the left. I was going to put in about 10.5 oz in each leg and call it good unless I should only put back "exactly" what came out ? Seems the left leg was a bit shy of what the manual calls for. I don't think we need to be absolute exact on these do we ? Noticed during the draining that the right leg came out black and dirty looking while the left oil came out red in color? Seems different oil was put in each leg ?
Also, anybody know the drain screw size for the legs ? Forks are chrome so I want to get some nice screws for replacement. Thanks for your help...
kevanbo is offline
post #2 of 7 (permalink) Old 07-21-2014, 05:46 PM
Harley has some nice chrome drain screws with sealing washers, come as a set. They weren't too expensive, I think around $10.00 give or take.
RebelRider is offline
post #3 of 7 (permalink) Old 07-21-2014, 08:53 PM
RoadGlideRider's Avatar
Just remember that the amount listed is the amount when dry.
When you drain anything, there is a residual amount left that make the refill amount lower.
RoadGlideRider is offline
post #4 of 7 (permalink) Old 07-22-2014, 11:58 PM
RoadGlide69's Avatar
I need to change the fork oil in my '09 and want to know how you are doing this? Are you completely removing the fork tubes as directed in the service manual?
I was thinking about just removing the nacelle to get to the tube bolts and change as I would any other HD I've done this on. Seems to be a big undertaking following the service manual.
2011 FLTRU Sunglo Merlot, VH Big Shot Duals, PC-V, A/N Big Sucker, CV Flasher & 14" WindVest Shield
RoadGlide69 is offline
post #5 of 7 (permalink) Old 07-23-2014, 01:20 AM
tdkkart's Avatar
Ive heard some say they drained it out the bottom, then made up a fitting to push the new oil back in the drain fittings with a syringe?? Might be worth a try if you can gather up the stuff.
Sent from Motorcycle.com App
tdkkart is offline
post #6 of 7 (permalink) Old 07-23-2014, 02:54 AM
Jetman's Avatar
Personally- I remove the forks to drain and change......Road Glide rider hit it when stating the manual lists a "DRY" weight amount of oil.
You may not have gotten equal amounts out due to additional being inside a damper or not all being flushed out correctly-ect.....
I would be sure and put in EQUAL amounts in each leg..... to ensure complete drainage, I pop the drian plugs and compress until nothing else comes out. I then pop the tops and turn the legs upside down for a bit (dinner-erands or even overnight)......Then add back my new oil & re-install. I liked the forks a little stiffer than stock so I used a heavier weight oil ( screaming eagle is heavier weight that the basic & it seemed to produce good result for me)....I also add a tad more.....I went w/ 11oz even..........
I would not be comfortable with draining while on the bike and trying to fill thro the drain plug........yeas it's a bit or work to remove, but it's really NOT that big a deal.......an hour or 2 to do it right is time well spent in my book......
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #7 of 7 (permalink) Old 07-23-2014, 11:28 AM Thread Starter
Got it done and all is good, although only rode it down to the gas station and back. Very easy procedure for those interested in doing it. I had just done the oil swap in my rear shocks so I wanted the front end to have some better damping with the heavier oil. Looking forward to a better ride with the "cheap" improvements. If anyone needs help with doing these suspension improvements just send me a PM and I'll be glad to help. My previous bike, an 06' SG had progressive rear shocks and SE oil in the front end so the stock set up on my 13' RGC was not cutting it. Terrible suspension from the factory !
kevanbo is offline
When to change fork oil? jcanrun Suspensions 18 04-10-2014 10:54 AM
Clunking after Fork oil change Road08Glide Suspensions 2 05-13-2013 08:55 AM
JUsta a couple of pics of the bus from the last couple of days! ChromeYellow67 *General Road Glide Discussions/Pictures 31 11-24-2012 11:41 AM
Fork Oil change rdnkjeeper Suspensions 6 04-09-2012 10:50 AM
Fork oil change pte359 Do-IT-Yourself 15 09-14-2010 05:04 PM
