lowering blocks & 994s - Road Glide Forums
post #1 of 6 (permalink) Old 03-14-2012, 10:24 PM Thread Starter
boudie's Avatar
Im SHORT!! Sick of tiptoeing. I just installed 994s to my 2010 FLTRX with an 18 inch rear wheel and 21 up front!!
Is it ok to run these with lowering blocks???
I need to get lower.
I am installing new monotubes for the front next week after Bike Week, so that will help some.
please help!!!!
Boudie
2010 RG, Denim Black, Klockwerks shield, Thunderheader, 103 SE ,255 cams,PM Wheels,J&M Rokker speakers,
boudie is offline
post #2 of 6 (permalink) Old 03-14-2012, 10:35 PM
Xaran's Avatar
Im not a fan of lowering blocks.
But if you do use them be sure to check your tire to fender clearance. if it rubs you may tear out the wiring.
the total travel for the 940 is about 3.25 inso measure your clearance with the block installed to be safe.
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #3 of 6 (permalink) Old 03-14-2012, 11:07 PM
ive used lowering blocks for 20k miles without issues. the biggest thing is to make sure theres enough clearance between tire and fender
post #4 of 6 (permalink) Old 03-24-2012, 09:24 PM
Shark of the Month October 13
Location: Was northern Maine, now gulf coast of Florida
Boudie - you have 944s? I called PS just a week ago and inquired about the difference between the 940 and 944 and checked availablity, and was told it would be 90 days/June before they shipped. I assumed that was going to be their first true production run, but maybe they've already sold so many that they're in a lengthy back order situation. I chose to order the 940s and hope I'm not giving up much to the 944s. I know I saved some decent money.
“Life should not be a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming “Wow! What a Ride!” - HST
Uncle Fuzzy is offline
post #5 of 6 (permalink) Old 03-24-2012, 10:32 PM
uhpilot's Avatar
If height was a problem, why did you go with an 18" rear instead of 17 or staying 16. A 200-50x17 is actually 3/4" lower than the stock 16 rear
Ricky
uhpilot is offline
post #6 of 6 (permalink) Old 04-21-2014, 11:19 AM
I think that*this information is*the best.
Gdemoitele is offline
Lowering blocks & 944's MightyWhitey Suspensions 0 05-19-2015 11:34 PM
Lowering blocks = burned wires.... Sethjamto *General Road Glide Discussions/Pictures 20 10-26-2012 03:13 PM
Lowering blocks amckay63 Classifieds Archive (3 months old+) 1 09-24-2012 11:28 AM
Progressive drop in fork and lowering blocks Betiobastard Suspensions 0 04-01-2012 03:44 PM
2012' RG custom -lowering 1" with blocks ? Wheelie *General Road Glide Discussions/Pictures 1 11-23-2011 05:56 PM
