Removing forks from Tree's - Road Glide Forums
post #1 of 10 (permalink) Old 07-22-2014, 05:53 PM Thread Starter
Z-SHARK's Avatar
I can't seem to get my fork legs to come free from the tree's.
I removed the top cap bolts from the forks.. And loosened up the pinch bolts.. Moved the fork pucks up the legs.. And sprayed cleaner on the legs.. Can't get them to even budge.
I've watched Norsemans great vid.. And also followed manual step by step.
Anybody have any ideas???
Fill with Gas... Twist throttle... Enjoy Life
Z-SHARK is offline
post #2 of 10 (permalink) Old 07-22-2014, 06:21 PM
Try putting the cap bolts back on and tightening them with the pinch bolts loose... once tight the tubes should turn in the tree- hopefully loosen things up for ya. You can even put a few washers between the cap and the cap bolts before tightening if ya have to...
V-man is offline
post #3 of 10 (permalink) Old 07-22-2014, 06:42 PM
If the tubes are real stubborn you can snug up the pinch bolts then put the front wheel on. With the front wheel on and the wheel on the floor you can loosen the pinch bolts and jack up the front end slowly, the weight of the front wheel should pull the fork tube loose. Once the fork tube move snug up the pinch bolts and jack up the bike and take the front wheel back off. If the tubes don't move when you jack up the front end you can leave the tire about a 1/4 to 1/2 inch off the floor and wiggle the front end and it should move.
post #4 of 10 (permalink) Old 07-22-2014, 06:46 PM
ERod62's Avatar
Try WD40 on triple tree where slide tube sets. If can pull it may try tapping on round bar or pin punch down the top bolt or cap.
If you damage the slide tube top nut assembly have my OEM setting around after going to monotubes PM if need them just pay shipping.
ERod62 is offline
post #5 of 10 (permalink) Old 07-22-2014, 07:37 PM
A piece of 2x4 and a baby sledge. A few light taps from the top and out she'll come.
post #6 of 10 (permalink) Old 07-22-2014, 08:00 PM
HUTMO's Avatar
My mechanic changed my front end from stock to chrome on my 2010. He said they we the toughest he ever experienced.
Gypsy Tour '14. - PA Route 6 and so much more.
HUTMO is offline
post #7 of 10 (permalink) Old 07-22-2014, 09:08 PM
My last bike they were a bitch to get out we really had to pound on them, I live near the water and you Gould see all the corrosion once they came out and the bike was only a few months old, they will come out eventually!
2013 RGU, black of course....
y2kflhr is offline
post #8 of 10 (permalink) Old 07-22-2014, 09:25 PM Thread Starter
Z-SHARK's Avatar
Thanks guys... I have one side out.. I used a ton of WD40.. Loosened the pinch bolt all the way.. Threaded the top cap in halfway.. And then used a rubber mallet.. medium to heavy taps on top of cap.. Then used the plastic end of a screwdriver to finish it out.. Threads seem fine so I'm guessing no damage done.
10 Years in the Desert Sun caked these babies on.
Well, back to work on the other side... thanks again.
Z-SHARK is offline
post #9 of 10 (permalink) Old 07-22-2014, 09:32 PM
mjsdouble's Avatar
Keep at it Mike. Wish I were closer to give you a hand.
mjsdouble is offline
post #10 of 10 (permalink) Old 07-22-2014, 09:34 PM
Q-Hog's Avatar
Mine came right out.. Keep up the effort and good luck...
Q-Hog is offline
Need help removing bent fork tubes from tree dvanlue Tech Area 6 09-02-2014 10:49 PM
how do the forks mount to the upper tree adown Suspensions 16 04-16-2014 10:37 PM
Removing Trap Door without removing Exhaust kevanbo Do-IT-Yourself 7 04-03-2014 07:01 PM
Removing & Installing Forks Q-Hog Suspensions 2 08-19-2012 04:36 PM
If This Tree Could Talk pte359 General Off-Topic Discussions 2 12-12-2010 04:57 PM
