Gettin to the fork caps - Road Glide Forums
post #1 of 15 (permalink) Old 07-22-2014, 10:33 PM Thread Starter
Ok, so I am thining on changing the fluid in the forks. Just looking it seems that the handlebars and gauge cluster have to come off. That right? Could anybody point me at a vid on how to do it? Found a good one on youtube but it was for a Streetglide which is a completely different animal in this regard.
I never saw a wild thing feel sorry for itself.--DH Lawerence
Tackdriver is offline
post #2 of 15 (permalink) Old 07-23-2014, 12:10 AM
Jetman's Avatar
Don't have a vid- but the bars do not have to come off. You do need to remove the speedo nacel. I find it easier to just remove the nacel all the way rather than just loosen - but as long as you can get to the fork caps your good.
You do need to remove the switch but that's not a big deal......
Of course- you'll need to remove the Fender- Calipers & Wheel
Loosen the caps then loosen the pinch bolts off the bottom tree plate. Once they are loose- remove the fork cap & slide down & out. Don't turn sideways or upside down or the fluid will spill everywhere. Re-install the fork caps while your handeling the fork legs... Once you change your oil, re-install in reverse order..... forks in- caps & pinch bolts tightened- nacel put back together- wheel calipers & fender back on.....
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
post #3 of 15 (permalink) Old 07-23-2014, 12:14 AM
Q-Hog's Avatar
++1^^^
Q-Hog is offline
post #4 of 15 (permalink) Old 07-23-2014, 12:48 AM
Not to high jack but does the ignition switch have to come off to remove the nacel?
post #5 of 15 (permalink) Old 07-23-2014, 01:01 AM
Q-Hog's Avatar
Yes, cause the gauge housing has to come off to get to the fork bolt caps.
Q-Hog is offline
post #6 of 15 (permalink) Old 07-24-2014, 04:21 PM
Its kind of a frustrating job to get to them, i actually have been wanting to raise my bike back to stock ride height but dont feel like dealing with taking that apart.
Meanwhile I am taking my transmission out and my primary is all apart. I'd rather do that than deal with the forks again.
I know people say it all the time, but go buy the manual for the bike. It is very easy to follow and worth its weight in gold.
Even the simplest tasks are in there and it makes sure you dont forget anything. Or do one of those, oh crap, i put that on before this and now i have to take something else off to accsess it....
2011 RG Custom, Screaming Eagle Stage IV (260 Cam), Barnett Scorpion clutch, Hayden M6, Baker DD7, V&H Throttlepak, V&H Power Duals w/Hi-Output Slipons
115.4 ft-lb & 122.7hp : 1/4 Mile 12.542 @ 105.99 w/stock clutch and transmission
gbourdon is offline
post #7 of 15 (permalink) Old 07-24-2014, 05:28 PM
HellInABucket's Avatar
You dont have to take the bars off. I changed my forks a few weeks ago, no need.
You do need a long wrench for the cap nut.
Basically you have to loosen or tighten slowly by putting the wrench on and turning the bars in the appropriate direction, take the wrench off, move the bars back, put the wrench on, move the bars, etc etc.
HellInABucket is online now
post #8 of 15 (permalink) Old 07-24-2014, 07:30 PM
Lucky D's Avatar
You can un bolt the handlebars and lay them on the gas tank. No need to take em completely off. It's only 4 bolts and makes things easier.
... Chrome?? We donneeedno stiinnkinng chrome.
Lucky D is offline
post #9 of 15 (permalink) Old 07-24-2014, 07:48 PM
No need to take the handlebars off at all.
But since you have the front end apart doing the forks it would be a good time to adjust the steering head bearings. JMO
post #10 of 15 (permalink) Old 07-25-2014, 12:49 AM
RoadGlide69's Avatar
I just changed my fork oil last night and did it without the hassle of removing the tire, fender and forks. Just put bars on the tank, move nacelle out of the way and loosen fork cap bolt and drain plug. Much easier that way imo..
2011 FLTRU Sunglo Merlot, VH Big Shot Duals, PC-V, A/N Big Sucker, CV Flasher & 14" WindVest Shield
RoadGlide69 is offline
Socket size for fork caps x52gnr *General Road Glide Discussions/Pictures 1 03-02-2012 10:31 AM
Gettin' the itch.... Quicksand Road Trip Discussions/Stories/Pictures 0 07-24-2011 08:55 PM
Gettin New Bars..... sftosendai Controls & Handlebars 4 06-15-2011 08:41 PM
Tornados - The south is gettin hammered Sincecrazy General Off-Topic Discussions 15 04-28-2011 07:21 PM
Gettin close to gettin it done Rowdy Engine Related 8 01-27-2011 09:10 AM
