31-2500 on Amazon 236.63 - Road Glide Forums
post #1 of 12 (permalink) Old 07-24-2014, 04:16 PM Thread Starter
93-331-29psi's Avatar
FYI for anyone seeking a new mono tube (standard height) kit. There are kits available on Amazon right now for 236.63 sold by Powersports Parts Plus.
93-331-29psi is offline
post #2 of 12 (permalink) Old 07-24-2014, 04:28 PM
What is it?
post #3 of 12 (permalink) Old 07-24-2014, 04:33 PM
DED HD's Avatar
standard height progressive monotubes
'10 Red Custom:
DED HD is offline
post #4 of 12 (permalink) Old 07-24-2014, 09:59 PM
RebelGlide's Avatar
wish that was for the lowered ones
2013 Road Glide Custom..Big Blue Pearl
D&D fat cat, Stage 1 AC, HD Tuner, So Cal HID, 12" Malo's, 8" KW and 12" WV, and other doodads.
RebelGlide is offline
post #5 of 12 (permalink) Old 07-25-2014, 08:27 AM Thread Starter
Here you go, 271 which is a great price
http://www.ebay.com/itm/190683999852...84.m1423.l2649
Edit, seller changed the price back to 340. No longer a great deal
post #6 of 12 (permalink) Old 07-25-2014, 10:29 AM
I've been watching these for a while now... how difficult is the install for them?
ksarauer is offline
post #7 of 12 (permalink) Old 07-25-2014, 11:28 AM Thread Starter
Installing just the mono tubes isn't too difficult. it's about a 2-3 hour job at best. If you get into new sliders it can take a little more time, but still not too hard. Norseman posted a video on the subject in the suspension section if you wanna get a good idea of what you're up against. We did Harley Hauler's last year in a couple of hours. Hardest part is getting those damn tabs to release the fender bolts.
post #8 of 12 (permalink) Old 07-25-2014, 12:15 PM
shane_huskey's Avatar
I wish I knew someone that had Monotubes so I could compare their bike to mine. Mine stock was horrible. Felt way too soft, dipped way too much, horrible feel when riding hard in tight curves. Recently, I switched over to heavy fork oil and overfilled just a little bit (about 2 oz if I remember right) and it is a world of difference compared to stock, but I would still be interested in seeing if the Monotubes are even more of an improvement.
shane_huskey is offline
post #9 of 12 (permalink) Old 07-25-2014, 12:36 PM
TYM2GLIDE's Avatar
I just did the monotube install 3 months ago, pretty straight forward with a service manual. You eill need a good vice to hold the slider when pulling apart, we used a cut rubber hose to assist with grip and prevent damage.
I dropped mine 1 inch when I added a 21, well worth the upgrade.
Good Luck!
2012 FLTRX, 4" Rineharts, V&H Naked V02, FullSack Head Pipe, 14" Malo's, Topshop Minister Fender & Viper bags, 21in Hogpro Titan wheel, Progressive monotubes with 1in drop, Andrews 57H cams.
TYM2GLIDE is offline
post #10 of 12 (permalink) Old 07-25-2014, 12:40 PM
TYM2GLIDE's Avatar
The monotubes are a great improvement, I have absolutely no fork-dive w/ heavy front breaking. Will be one the first things I ever do w/ every ride I have.
Robin Williams dead at 63 Bruckus General Off-Topic Discussions 13 08-12-2014 11:19 AM
Monotube 31-2500 with no preload clips? V-man Suspensions 9 07-10-2014 12:29 PM
Any tried the Infinity 63.9i Bubba Audio 5 04-27-2014 11:55 PM
Option to amazon? DOOFUS General Off-Topic Discussions 20 03-21-2013 06:36 PM
