Lowering kit for Progressive 940s - Road Glide Forums
post #1 of 4 (permalink) Old 07-25-2014, 06:01 PM Thread Starter
Does anyone make a lowering kit that will work with Progressive 940 rear shocks? Not having an issue due to lack of height just wanting to give the bike a more raked look.
thebean is offline
post #2 of 4 (permalink) Old 07-25-2014, 06:21 PM
Any of the lowering kit's that work for oem shocks should work with the 944's
post #3 of 4 (permalink) Old 07-26-2014, 09:53 AM Thread Starter
I would have thought that also but I read the description on a couple different kits and they both said for use with factory Harley air shocks only. I also looked into this some time back and remember reading on a forum that the problem had something to do with the 940s having a larger diameter.
thebean is offline
post #4 of 4 (permalink) Old 07-26-2014, 10:14 AM
I've used lowering kits before but not on NON oem shocks, so I can't say with 100% certainty. All the kit do are move the bottom of the shock back a bit.I would think if it fits in the oem spot it will fit in the lowering kit .
hd lowering Cartridge Fork Kit or progressive lowering kit IranAround Suspensions 11 03-21-2015 01:09 PM
Progressive 940s ordered mastergunnera8 Suspensions 29 06-17-2012 02:26 PM
Got the monotubes and 940s. Now I want a new kickstand! jcontonio Suspensions 10 06-07-2012 06:09 PM
Progressive "Drop in lowering kit" roadglide007 Suspensions 2 09-08-2011 11:37 PM
