Shotgun Bagger Shocks... - Road Glide Forums
post #1 of 28 (permalink) Old 07-27-2014, 10:03 PM Thread Starter
Have had the Shotgun Bagger Shocks on ~2 weeks now and am very pleased with them and their performance. Fortunate to live within a few hours of JD and his shop, was able to have the install completed there. He has redesigned the system in which the compressor is mounted directly to the back of the right side shock. Should there be any required access to the compressor, whalla, there it is without having to get under the bike, etc, etc. Air lines run into a "Y" connection, then to the compressor; wire harness to the battery and mounting plate with switches, and you are done.
System raises and fills quickly (~10 seconds, little more for desired firmness), then set the ride height/rebound and off you go. My '13 FLTRX (while on sidestand) sits at 6.25" lowered and raised is at 10.25", that allows for quite the adjustments when needed. I do freeway riding to work (softer ride); on way home, I can choose a number of alternate routes that allow for more fun with twisting curves (adjust to firmer ride) and less traffic; all adjustments done with a simple flip of the switches.
System is rock solid, as also as most know, customer service from JD and his crew is above and beyond.
2013 FLTRX
USMC 1987-Present
dan8411 is offline
post #2 of 28 (permalink) Old 07-27-2014, 10:08 PM Thread Starter
Pics are from right side; bike on sidestand. With bike upright, measures just over 5" and 9" respectively.
2013 FLTRX
USMC 1987-Present
dan8411 is offline
post #3 of 28 (permalink) Old 07-27-2014, 10:28 PM Thread Starter
A few pics of it raised and lowered...
2013 FLTRX
USMC 1987-Present
dan8411 is offline
post #4 of 28 (permalink) Old 07-27-2014, 10:32 PM Thread Starter
And backside...
2013 FLTRX
USMC 1987-Present
dan8411 is offline
post #5 of 28 (permalink) Old 08-08-2014, 05:44 PM
Originally Posted by dan8411 View Post
And backside...
Looks good, i had his shotgun on my softail and it was awesome also. Waiting to put them on the glide. What rear fender and bags are you running?
2016 Road Glide Charcoal Pearl. 6.5 stereo installed.
Black Thunder Header 2-1
FP3 tuner
LUCKY13 is offline
post #6 of 28 (permalink) Old 08-09-2014, 01:41 AM Thread Starter
Setup is from TopShop; CVO Minister fender and full stretch NewStyle bags.
2013 FLTRX
USMC 1987-Present
dan8411 is offline
post #7 of 28 (permalink) Old 08-09-2014, 02:38 AM
NorCal's Avatar
any thoughts on replacing your temp gauge with a PSI gauge for the shocks??
NorCal is offline
post #8 of 28 (permalink) Old 08-13-2014, 11:42 PM Thread Starter
Hadn't given any thought to it, I'm dialed in with the system and rides great. Besides, how would I be able to tell when it isn't 78 degrees here in SoCal?
2013 FLTRX
USMC 1987-Present
dan8411 is offline
post #9 of 28 (permalink) Old 09-04-2014, 04:36 PM
I have his older style (got it a few months ago) and yours looks like it sits lower aired up than mine...does he have different length options now?
zslow6 is offline
post #10 of 28 (permalink) Old 09-10-2014, 01:33 AM Thread Starter
Not sure of any different lengths offered; changed the design of the body I believe to allow a little more space between bags/shocks, mounting compressor on body and to allow pass backrest to install (think last design didn't allow pass backrest).
2013 FLTRX
USMC 1987-Present
dan8411 is offline
One set of Shotgun Shocks Shocks only*** HogPro Parts for Sale 2 02-04-2015 01:53 PM
Shotgun Bagger Suspension zslow6 Suspensions 1 05-24-2014 11:47 PM
Bitchin Bagger Shocks Swagzilla Suspensions 10 03-23-2014 05:18 AM
Bitchen Bagger shocks oldtimer63 Parts for Sale 11 03-19-2014 11:52 AM
How about a HD Shotgun? SharkNose General Off-Topic Discussions 1 11-07-2011 03:58 PM
