Just installed Progressive Monotubes - Road Glide Forums
post #1 of 14 (permalink) Old 08-02-2014, 08:36 PM Thread Starter
faststan's Avatar
I just installed the lowering Progressive Monotubes 1" lower (I already had Profile low springs installed). So basically same height as what I had. The ride difference is amazing. Aside from having to buy a 1 3/8 socket and some fork oil and bottom screws/w compression washers, it was fairly easy.
So, if you are sitting on the fence about these you are missing out on a fine tuned ride. Even an old fart can do this.....
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #2 of 14 (permalink) Old 08-02-2014, 11:03 PM
93-331-29psi's Avatar
I just got done installing mine 15 minutes ago also 1" lower (to compensate for the 21). Can't wait for the rain to stop.
Sent from Motorcycle.com App
93-331-29psi is offline
post #3 of 14 (permalink) Old 08-02-2014, 11:07 PM
After I get a few non bike related items taken care of the progressive monotube will be next
post #4 of 14 (permalink) Old 08-17-2014, 10:06 PM
RoadGlideGary's Avatar
Putting my bike on the jack this week to do the Monotubes, powdercoated lowers and cowbells and check the neck bearing. All done in time for Fall riding season and ready to roll for SWV!
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #5 of 14 (permalink) Old 08-17-2014, 10:10 PM
Q-Hog's Avatar
Sounds good.. you'll like the how the monotubes improves the comfort of your riding.
Q-Hog is offline
post #6 of 14 (permalink) Old 08-17-2014, 11:30 PM
wachuko's Avatar
Thumbs up
This is another thing that I have on the list of mods for mine... always procrastinating because I thought it was a lot of work to get them in place...
How much do you have to take out to drop them in? I guess that is time to search for a few how to's and videos.
Let's see... LED headlights, Monotubes (standard height, not lowering mine), new caps for clutch and brake fluid reservoirs (starting to show some corrosion)... almost there...
Ride Safe! Wachuko - 2016 HD Softail Slim S / 2016 Triumph Thruxton R
2014 RK CVO Tribal Orange-Galatic Black (Gone) / 2013 HD Forty-Eight in Ember Red Sunglo (Gone)
wachuko is offline
post #7 of 14 (permalink) Old 08-18-2014, 03:33 PM
Yep there is a very good post in the suspension section on how to install. Done by a "tank" member - he posted on youtube and provides the link. You will also want to do a search on the ignition removal - another good post with a youtube link. Not to difficult to accomplish the entire task - just watch the videos a few times and gather the tools and take your time. To me the scariest part was the ignition removal - but after watching the video, making the tool (1/4" copper pipe flattened) and actually removing and replacing a few times it was super simple.
Lots of hands-on useful advice here in the Tank.
post #8 of 14 (permalink) Old 09-05-2014, 01:48 AM
GermanyBert's Avatar
Is it necessary to remove the fariing to install these?
GermanyBert
2011 Road Glide Ultra
2002 Sportster 883/1250 Stage II
GermanyBert is offline
post #9 of 14 (permalink) Old 09-05-2014, 02:30 AM
tdkkart's Avatar
no
tdkkart is offline
post #10 of 14 (permalink) Old 09-05-2014, 04:01 PM
Shrug's Avatar
Remove the instrument nacelle to expose the fork tube bolts. Hold on tight when those suckers pop lose and avoid putting your face directly over them. Don't ask me how I know.
Shrug - Scott Wilson
2010 FLTRX "Hester 2.0" -
Shrug is offline
Best Source for Progressive MonoTubes Shrug Suspensions 10 03-26-2012 02:48 PM
Fork upgrade: progressive spring vs monotubes ilmanzo31 Suspensions 8 03-05-2012 12:37 PM
progressive monotubes THEMASTERDESTROYER Suspensions 0 03-03-2012 06:27 PM
Installing progressive monotubes how to?? jbrawkus Suspensions 6 12-12-2011 05:16 AM
Progressive 940 Shocks Just Installed Marco V Road Glide Specific Discussions 0 11-01-2011 10:42 PM
