What length 6mm allen driver - Road Glide Forums
post #1 of 7 (permalink) Old 03-26-2012, 09:37 PM Thread Starter
I've looke at a dozen threads on Fork removal, couldn't find one that has the lenth of the 6mm Allen wrench used to remove the slider bolts from the bottom of the forks.
How long does it have to be, thanks.
Sealdoggy is offline
post #2 of 7 (permalink) Old 03-26-2012, 09:47 PM
FrankieB's Avatar
What i used was about 6 inches long. Don't use a ball end allen, it will strip out the bolt head. If you have a harbor freight you can pick up a cheap set of metric allens for a ratchet.
06 RK
11 RGU
FrankieB is offline
post #3 of 7 (permalink) Old 03-26-2012, 09:47 PM
I have snap-on's long allen about 4 inches long
thekidd is offline
post #4 of 7 (permalink) Old 03-26-2012, 10:08 PM Thread Starter
Thanks much, I heard that is it recommended to change out the bolts or can you use the ones you took out.
post #5 of 7 (permalink) Old 03-27-2012, 10:17 AM
joke's Avatar
Change out the bolts when you get the rest of the o-rings, etc.
The Allen wrench is about this long...
2009 Mirage Orange
joke is offline
post #6 of 7 (permalink) Old 03-27-2012, 11:39 AM
JJSW1283's Avatar
I picked up a long metric set on ebay w/ the ball end. Used with an impact gun and had no troubles.
JJSW1283 is offline
post #7 of 7 (permalink) Old 03-27-2012, 07:20 PM
EdY39's Avatar
I cut one 2 " long years ago, inserted into a socket, use with a ratchet or impact wrench and it's worked ever since.
Ed
2002 RoadGlide
DPCM, USN (Retired)
EdY39 is offline
Torx and Allen head sizes Cvilledustin *General Road Glide Discussions/Pictures 7 07-08-2017 02:24 PM
Allen Wrench Size BSwig Suspensions 1 09-11-2014 07:55 PM
help with allen wrench size infantrydan80 Do-IT-Yourself 3 05-23-2012 09:32 PM
