JRI 12b or 13b for fltrx - Road Glide Forums
post #1 of 8 (permalink) Old 08-12-2014, 11:42 AM Thread Starter
These stock shocks have to go asap. Does the 12b sit much lower than stock while riding..i know its supposed to be 11 inches...any bottoming out. Not really sure I want the rear of the bike up another inch with the 13b even though they are at 12 inches or 11.8 while riding like the stock set up.
jason605 is offline
post #2 of 8 (permalink) Old 08-12-2014, 11:52 AM
Scoop's Avatar
Your Custom sits about an inch lower than my Ultra. I got the 13" JRI B's It didn't change my ride height, but improved the handling like you can't believe. Bottoming out is controlled by how you initially set up the spring pre-load. Follow the instructions given by Howard at Motorcyclemetal and you can't go wrong.
One satisfied customer.
John
2011 FLTRU Fullsac Sportpipe, SE Breather/air cleaner, SEPRT Smart-tune, Corbin, Madstad 13", Gold Top Fork Emulators & Springs & JRI B shocks. 2003 XLHS
Scoop is offline
post #3 of 8 (permalink) Old 08-12-2014, 11:53 AM
I'd do 13". The shorter the shock the more parts I scrape on the ground. But that is just me.
HogPro is offline
post #4 of 8 (permalink) Old 08-12-2014, 11:57 AM
Scoop's Avatar
More travel = more comfort!
Scoop is offline
post #5 of 8 (permalink) Old 08-12-2014, 01:11 PM
Unless you are vertically challenged I would go with the longer shock.
2013 Ultra
Pics here:
rg_dave is offline
post #6 of 8 (permalink) Old 08-12-2014, 01:48 PM
Bull_Duck's Avatar
For my '08 FLTR I chose to maintain the factory height. So 13" JRI B rear with matching Progressive Monotube in front. Outstanding ride, confirmed with 1,200 miles last month on twisty mountain roads in Colorado.
When I want to ride low and cool, cruising, I power up my 2000 Deuce. Too much chrome and good-ol-fashioned manual carb go-power. Varoom.
So I have the good fortune of having and continually improving purpose specific bikes. For me, one does not do it all. Not that I am rich; rather, I don't mind riding bikes or driving cars that have a lot of years and miles on the meter. Ymmv.
Your want or need circumstances may require a do-it-all. If so, then you must make compromises. Only you can weight the compromises.
Bull_Duck is offline
post #7 of 8 (permalink) Old 08-12-2014, 02:21 PM
tj316's Avatar
Have you considered Ohlins ? Go with the Ohlins #3-#3 , great shock 12 3/4" long , kind of in the middle as far as height , JRi B's and Ohlins #3-#3 cost about the same
tj316 is offline
post #8 of 8 (permalink) Old 08-12-2014, 11:03 PM
13's and Mono Tubes on mine as well.
Different bike now.
I hate this word, but it's "plush".
2010 Vivid Black Road Glide Custom
Mike Jesse is offline
12" Pro-Action Touring Shocks (PA-SSS-12B) Bunker Parts for Sale 1 04-13-2017 07:10 PM
JRI vs Ohlins tj316 Suspensions 18 04-19-2015 04:01 PM
JRI Shocks Ordered Scoop Suspensions 38 09-10-2013 07:45 PM
JRi 12" Shocks Initial Review jimmyray11349 Suspensions 2 10-27-2012 02:29 PM
Ordered JRI Shocks today jimmyray11349 Suspensions 9 10-15-2012 09:38 PM
