Arnotts Bilstein - Road Glide Forums
post #1 of 16 (permalink) Old 04-04-2012, 02:04 PM Thread Starter
Arnotts Bilstein
Can't find to many reviews on the arnott bilsteins but probably looking to make a purchase pretty soon. Im currently riding on 1' lowering blocks on stock 13" and its pretty smooth. Will the bilsteins give somewhat the same ride and is there high speed wobbles at 80+?
Betiobastard is offline
post #2 of 16 (permalink) Old 04-15-2012, 11:21 AM
reficul's Avatar
A couple of my friends are running the Arnott systems, They absolutely love them. They swear they are way better than the legends air ride and cost a lot less. When you two up you just add air, these guys run them flat most of the time so they can drag there bags (dont ask) I am interested in picking up a set but i have ABS which is in the way of mounting the air compressor behind the side cover on the left side. So i have to decide either mounting it in bags or behind the fairing. My first choice is the fairing since i dont like my bags cluttered. hope this helps
2012 Shark Face
One day he is gonna answer
reficul is offline
post #3 of 16 (permalink) Old 04-15-2012, 03:15 PM
oleschool's Avatar
arrnott bilsteins
i've been running the arnott bilstein air ride for about 2 1/2 years,they have performed flawlessy for me.i have a 09(with abs) and mounted the compressor in front of the battery.some folks say it won't fit ! guess what,it fits.all you need is a little patience and a little coaxing and it goes in.as far as the wobble you talk about,i've never had a prolbem with that.
oleschool is offline
post #4 of 16 (permalink) Old 04-15-2012, 03:21 PM
DonJulio's Avatar
Why not do the home made air ride for like $150 ???
DonJulio is offline
post #5 of 16 (permalink) Old 04-15-2012, 04:01 PM
DonJulio's Avatar
DonJulio is offline
post #6 of 16 (permalink) Old 04-15-2012, 05:35 PM
uhpilot's Avatar
Careful when reading reviews. Arnott has 2 different air rides. The bilsteins for around $600 and the others for around $1000. So when you read "they are great" they might be referring to the $1000 set.
The bilsteins don't have different settings where as the others have a an 11 position ride setting.
Ricky
uhpilot is offline
post #7 of 16 (permalink) Old 04-16-2012, 07:31 AM
reficul's Avatar
I was referring to the $600 set. A friend of a friend just installed one this weekend on his batwing. Everybody seems to love them. I have seen some bad reviews on other forums but the guys i know running them swear by them
2012 Shark Face
reficul is offline
post #8 of 16 (permalink) Old 04-16-2012, 07:35 AM
reficul's Avatar
Oleschool You have any pictures of your install? I was gonna eliminate the air compressor and use a CO2 bottle from a paintball gun with a regulator. a 3 1/4 dia. by 10" bottle holds 3000 psi at 45 cu. in. of volume and just mount it in the bag
2012 Shark Face
reficul is offline
post #9 of 16 (permalink) Old 04-16-2012, 07:37 AM
reficul's Avatar
Donjulio whats the $150 dollar version you speak of? the corvette shocks?
2012 Shark Face
reficul is offline
post #10 of 16 (permalink) Old 04-16-2012, 07:54 AM
CNMTurner's Avatar
Does anyone know which Bilstein shock is used in this system? Seems you could use this shock in place of the Monroe Corvette shock and eliminate the over extend problem of hitting the pipes with the 14" Monroe.
2010 FLTRX - Stage 4 SE 113 - MVA Heads, 10.5:1, SE266E cams, 58mm TB, 5.3 gr/s injectors, Polished and plated motor and trans and a few chrome extras. Fullsac DX Header and Freedom Performance Classic 4" Slip-ons. Titan II 6.5 speakers with RF PBR300x2, Monroe Airshocks
1996 Tail dragin' Fatboy
CNMTurner is offline
just got my arnotts citified Suspensions 35 01-31-2013 10:46 AM
-2 monotube and arnotts airride pimpsarus Suspensions 26 12-29-2012 03:49 PM
Arnott Chrome Bilstein 12" air shocks cmacclel Sold 7 10-29-2012 12:07 AM
Arnot Bilstein Video cmacclel Suspensions 7 10-02-2012 06:36 PM
Progressive/arnotts pricing??? jbrawkus Suspensions 14 04-22-2011 07:16 PM
