Lowering Forks vs Travel loss - Road Glide Forums
post #1 of 11 (permalink) Old 04-06-2012, 12:56 AM Thread Starter
nvmike24's Avatar
I want to lower the suspension on my RGU. I do not want to lose travel in the process and want to be able to set sag correctly. This seems to be a little spoke of topic. Removing spacers and progressive springs are the norm it seems. Has anyone measured the loss of travel/sag with the lowering kit installed?
nvmike24 is offline
post #2 of 11 (permalink) Old 04-06-2012, 10:10 AM
Sedona103's Avatar
Not to point out the obvious but you are planing on lowering the bike thus reducing the amount of travel that the suspension has but you don't want to lose travel? Your best be in lowering the bike is to find a setup that still has a fair ammount of spring rate variation to maintain a comfortable ride however you will inevitably loose travel.
2011 fltrx w/ 103.
My build thread.
Sedona103 is offline
post #3 of 11 (permalink) Old 04-06-2012, 12:18 PM Thread Starter
nvmike24's Avatar
Actually I'm looking for 1" shorter tubes to accomplish the task of lowering the front without losing travel. Thought I read somewhere other HD forks would do it but can not find the info again.
I am here: http://tapatalk.com/map.php?ywuhy3
2016 FLTRSE, V&H X Pipe, Power Vision Tuner, New to me 5-18-2019
nvmike24 is offline
post #4 of 11 (permalink) Old 04-06-2012, 01:00 PM
tdkkart's Avatar
Pretty much no matter what you do, the limiting factor is the point where the front fender wacks the bottom of the lower triple tree. Using the stock components the fork can only go so far before it bottoms.
tdkkart is offline
post #5 of 11 (permalink) Old 04-06-2012, 05:36 PM
HD spends tons of money in Research & Development to come up with the best handling bikes possible. So lowering a suspension will affect handling and ride. There are aftermarket suspension companies that offer a variety of upgrades but any upgrade that lowers the bike will affect the handling of the bike. Lowering the bike may make it look COOL but it will affect the ride and handling of the bike, stick with the same height suspension if you can because it is best for ride and handling.
post #6 of 11 (permalink) Old 04-06-2012, 06:23 PM
Shark daddy's Avatar
I disagree with Ironmark. I have lowered my front two inches and the back 1 inch with the 940's and progressive cartridge inserts and I feel my bike handles better, but is a little rougher riding.
"Don't Cheat yourself, Treat yourself"
2015 Superior Blue RG Special
Shark daddy is offline
post #7 of 11 (permalink) Old 04-07-2012, 02:03 AM
Not only does the bike ride rougher but you also loose lean angel. HD engineers would make the bike lower if there was a handling and ride advantage. HD does have proving grounds facilities that extensively test all the models that they manufacture. As far as I know the manufactures of aftermarket lowering kits and suspensions do not have the test facilities that would equal HD.
post #8 of 11 (permalink) Old 04-07-2012, 03:14 AM
tdkkart's Avatar
Wanna talk about the obscene(and dangerous) brake dive that the 09-up models have and the Progressive monotube inserts eliminate, while also making the ride and handling much better??
What's safer, being able to flat foot when you stop or having to try to handle the bike on your tip-toes. None of Harley's touring models are very ergonomically friendly to those of us with less than 32" inseams. Therefore, lowering the suspension, front, rear or both makes for a safer riding experience.
The MoCo has alot of stuff to factor in when designing suspensions. What they end up with is a best-guess compromise of alot of factors, not the least of which is cost. To say that a aftermarket replacements for some components cannot be better is pretty short sighted.
tdkkart is offline
post #9 of 11 (permalink) Old 04-07-2012, 08:14 AM
swede0030's Avatar
You may want to read these post on H-D Forum concerning front fork changes. I made this change (lowered front 1") along with Ohlins 3-3 rear and it dramatically changed handling without sacrificing ride quality.
Search below on H-D Forum
Who wants their Ricor Intiminators to work better?
Jim
09 CVO rear, Ricor intiminators, Ohlins 3-3, Blade wheels, Corbin Solo, KW 1 1/4" heritage bars, Zumo 665, Chopped TP,255se cams, Bub 7's, Touring Duals, PCV
2011 RGU
swede0030 is offline
post #10 of 11 (permalink) Old 04-07-2012, 10:34 AM Thread Starter
nvmike24's Avatar
Thanks everyone for your input. Having come from the sport bike world making change like I suggest would not be as much of a problem. I am used to setting sag at about 25-30% of suspension travel for the best suspension operation. Looks like I'm getting too OCD trying to correct the fit and brake dive with just suspension changes alone. Ricor, Progressive & Race Tech all have Spring/Valve changes that will cure the braking issue I believe. The suspension Techs I have spoken to say once I do the front I will see where the back will need to be changed as well. That being said if I'm going to spend $1200 in suspension upgrades I would like to get it right the first time, I read here, only buying it once. Looks like I may be better to change the seat to achieve the lower position. Laughlin River Run is just a couple weeks and a 1/2 tank of gas away.
nvmike24 is offline
Stock vs Arnott vs Legends vs HD Premium SEUGOT1 Suspensions 15 04-25-2017 11:10 AM
Thundermax vs DynoVision vs PwrPro Black vs FP3 stillsoldier4christ ECM/Fuel Management systems 16 10-01-2016 01:42 AM
hd lowering Cartridge Fork Kit or progressive lowering kit IranAround Suspensions 11 03-21-2015 01:09 PM
Lowering stock front forks????? Louster47 Suspensions 5 07-07-2013 03:45 PM
Lowering blocks VS Changing Shocks hamer007 Suspensions 5 01-29-2013 07:50 AM
