Better Suspension w/o lowering? - Road Glide Forums
post #1 of 7 (permalink) Old 08-28-2014, 02:35 PM Thread Starter
Everywhere I look on the web, I read praise for Progressive cartridges for front end. But, comments always include remarks about lowering.
I want better suspension for my '13 RGU, but have no interest in lowering it. I like ground clearance.
Can someone point me in the right direction? Thanks!
August is offline
post #2 of 7 (permalink) Old 08-28-2014, 02:46 PM
JayKS's Avatar
JayKS is offline
post #3 of 7 (permalink) Old 08-28-2014, 02:46 PM
tj316's Avatar
what do you want to spend ?? Ohlins 101 Cartridges are around $900 and worth every penny , you can add Ricor valves to your current forks which are an improvement but not in the same league as Ohlins , they are a few hundred dollars
tj316 is offline
post #4 of 7 (permalink) Old 08-28-2014, 02:48 PM
tj316's Avatar
[QUOTE=JayKS;2154602]They make two monotube kits. One for stock height and another for lowering:
The stock height kit still lowers it about 1"
tj316 is offline
post #5 of 7 (permalink) Old 08-28-2014, 02:51 PM
JayKS's Avatar
Mine didn't. When I had the stock height monotubes with, I think 3 spacers installed, I maintained stock height.
I've since gone with a 21" wheel and installed the lowered monotubes in the -1" config.
JayKS is offline
post #6 of 7 (permalink) Old 08-28-2014, 02:58 PM
tj316's Avatar
I installed them before going to Ohlins and 49mm forks, went with the stock height and recommended number of C clips , it lowered my bike almost 1 " , they are still in my 41mm forks sitting in the corner of my garage , I was surprised because I had the lowered ones on my previous bike set up at 1" lowered and these were only slightly taller , I took measurements before and after and it dropped between 3/4"-1"
tj316 is offline
post #7 of 7 (permalink) Old 08-28-2014, 03:05 PM
tj316's Avatar
look at my cow bells in these 2 pictures , the one where they hit just on the top of my fender is stock suspension with Ricor Intiminators , the one where the cow bells are down lower on the side of my fender are monotubes standard height with 3 C clips
tj316 is offline
Is 18 suspension better? WAZMAN Suspensions 8 09-16-2017 09:28 PM
hd lowering Cartridge Fork Kit or progressive lowering kit IranAround Suspensions 11 03-21-2015 01:09 PM
Progressive Suspension Monotube Fork Lowering Kit part number 31-2501 daryl_db Parts for Sale 4 03-11-2015 11:22 PM
Lowering Suspension Options Blue Shark Nose Suspensions 22 05-24-2012 11:46 PM
Racetech Fork Suspension and Lowering Kit TracyB Classifieds Archive (3 months old+) 9 02-20-2012 06:37 PM
