Front suspension 'rough' - Road Glide Forums
post #1 of 14 (permalink) Old 04-09-2012, 03:20 PM Thread Starter
Hi folks, need help. My 2011 RGU rides extremely rough in the front end. Tire is at 36 psi, rear shocks I've tried at 20 - 40 lbs.. and still rough either one up or two up.
Is there an adjustment on the front forks that I've missed or ??
Thanks for the help
Mike
mpears53 is offline
post #2 of 14 (permalink) Old 04-09-2012, 05:13 PM
Shark daddy's Avatar
Did you purchase the bike new? If you did, I have never heard anyone comment on a hard ride.
If you purchased used, maybe the previous owner replaced the fluid with a race weight fork oil?
If you figure out what's going on, let us know.
"Don't Cheat yourself, Treat yourself"
2015 Superior Blue RG Special
Shark daddy is offline
post #3 of 14 (permalink) Old 04-09-2012, 05:22 PM
cyclescoot's Avatar
You haven't missed anything...you just haven't installed the Progressive Monotube front end yet.
It is good.
2011 FLTRX Vivid Black 103 power pack'd | FuelMoto Headpipe & AC | DynoJet PowerVision | Jackpot 4" & CFR KO's | Progressive 940's & Monotubes 1"lowered | 12" Windvest | Boom! speakers | WildOne's 515 MiniApes | Vented Lowers | TourPak w/AirWing
cyclescoot is offline
post #4 of 14 (permalink) Old 04-09-2012, 06:10 PM
tdkkart's Avatar
Just like nearly every other sub-system on a Harley, the fix for it is to remove it, throw it in the corner, and replace it with parts that function as they should.
In this case, remove the front forks, unscrew the top caps, pour out everything inside and replace with Progressive mono-tubes. The ride will be MUCH better.
tdkkart is offline
post #5 of 14 (permalink) Old 04-09-2012, 09:43 PM Thread Starter
i bought bike brand new... front end seems to bang on the bumps and I've ridden other bikes and they just float over most bumps... Thanks to all for your input on the Progressive mono-tubes.
mpears53 is offline
post #6 of 14 (permalink) Old 04-09-2012, 09:49 PM
Another vote for the monotubes, not enough can be said about them, IMO.
post #7 of 14 (permalink) Old 04-10-2012, 09:46 AM
Xaran's Avatar
+1 for Monotubes. At this time I think they are the best solution available for the front.
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #8 of 14 (permalink) Old 04-11-2012, 02:13 AM
Sounds like a fork oil/air problem that's keeping the fork from damping. I'd at least check the oil level and viscosity, and compress as much air out of the tube as possible before spending money on parts, and new oil!
keysrider3 is offline
post #9 of 14 (permalink) Old 04-21-2012, 11:18 AM Thread Starter
Keysrider3
Thanks for the idea, will try the cheap and simple solution first.
Mike
mpears53 is offline
post #10 of 14 (permalink) Old 04-21-2012, 11:23 AM
Triplej's Avatar
Does it seem as though the forks are bottoming out or it is possible it is loose head bearings you are hearing when going over bumps?
Triplej is offline
Tags
forks , front end
Repainted bike, surface feels rough after buff/polish TKsBlueGlide Paint & Bodywork Section 8 05-01-2013 04:19 PM
Today was a rough one CHAINSAW General Off-Topic Discussions 46 04-23-2012 10:39 PM
rough idle todd choops Troubleshooting for Road Glides 3 03-27-2012 09:36 AM
Fltruse runs rough smitty *General Road Glide Discussions/Pictures 5 08-12-2011 10:16 PM
