Head Bearing - Road Glide Forums
post #1 of 13 (permalink) Old 09-14-2014, 12:05 PM Thread Starter
RoadGypsy's Avatar
Head Bearing
I recently (2 months ago) bought a 2013 Road Glide Ultra, with 7,200 miles on it. Great bike. Love it, and a huge step up from my 2004 FLHRCI.
I had the bike in at my local dealer, swapping some parts out. They told me my head bearing was loose. They told me I could leave it to fix later, but it would cause some wobble in the steer at low speeds (below 45 MPH). I had already noticed an occasional wobble a few times at lower speeds.
Should a bike that is 1 ½ years old, with less than 8K miles, have this problem?
Thanks for the feed back.
RoadGypsy is offline
post #2 of 13 (permalink) Old 09-14-2014, 12:50 PM
ERod62's Avatar
Common issue on the RG from 2009 to 2013. Just adjusted as per manual instructions and enjoy the ride.
ERod62 is offline
post #3 of 13 (permalink) Old 09-14-2014, 01:19 PM
tdkkart's Avatar
Brand new bikes with near zero miles have this problem. Many bikes seem to come up with loose neck bearings very early in life. The MoCo apparently doesn't have any engineers that know how to set preload so it stays put for more than a few miles.
My '11 RGU was loose, when I went to adjust it the nut that sets the preload was not even finger tight(if you could have reached it with your fingers). The fall-away was WAY off, front wheel flopped like a flag in the wind.
Anyway, get it adjusted and greased, it'll be fine from there on most likely.
tdkkart is offline
post #4 of 13 (permalink) Old 09-14-2014, 03:25 PM Thread Starter
RoadGypsy's Avatar
Thanks for the info. I never had a problem with my '04 RK. Just seems premature to me. Hope it'll late more than another 8,000 miles.
Ride safe.
post #5 of 13 (permalink) Old 09-14-2014, 04:23 PM
ERod62's Avatar
Yep MOCO missed this one.
ERod62 is offline
post #6 of 13 (permalink) Old 09-14-2014, 08:56 PM
Had mine adjusted at the 1k service and 14k later it needs it again. I'll do it myself this time.
DuraGlide is offline
post #7 of 13 (permalink) Old 09-14-2014, 09:14 PM
torqu's Avatar
Had the issue at 42 miles on my brand new 2013 Fltrx. It about put me in the ditch. Needless to say I fixed the problem by cutting the neck and running a 26" front wheel. No more trips to the dealer. Lol. But yes mine were very loose from the factory. Pulled both hands off of the handlebars to zip up my pockets and it shook back and forth. It was crazy.
torqu is offline
post #8 of 13 (permalink) Old 09-14-2014, 09:56 PM
ChivoChavez321's Avatar
Mine had the problem also. AAANNNDDD the stealer had the audacity to charge me to adjust it!
2013 Big Blue Pearl Road Glide Ultra. Monster Ovals, Jackpot Ceramic Headers, Fuel Moto Power Vision and Billet Air Cleaner, Oil Temp guage, saddle bag bumpers, 11.5" rear progressives 444, monotubes -1, Woods TW-777 cam 107 FM kit with Level B Heads, polished throttle body. 123 Torque/113HP. "Lord, help me to be half the man my dog thinks I am"
ChivoChavez321 is offline
post #9 of 13 (permalink) Old 09-14-2014, 10:18 PM
perrykw's Avatar
Had mine adjusted too. Per the dealer it's a normal maintenance item but HD does allow them to adjust it once under warranty.
perrykw is offline
post #10 of 13 (permalink) Old 09-14-2014, 10:27 PM
NorCal's Avatar
my dealer adjusted mine at 22K under warranty
NorCal is offline
Adjust your Steering Head Bearing...easy hotrodad Tech Area 56 10-25-2013 07:43 PM
Help with Steering Head Bearing Adjustment twistr Troubleshooting for Road Glides 15 07-23-2013 09:32 AM
Question on Greasing the Steering Head Bearing Teagatron3000 Do-IT-Yourself 32 04-13-2013 11:46 AM
steering head bearing adjustment question sgrooms Troubleshooting for Road Glides 10 03-28-2013 06:17 AM
Steering Head Bearing - Help 1st Sgt Do-IT-Yourself 8 10-07-2012 06:41 PM
