how much fork oil? - Road Glide Forums
post #1 of 12 (permalink) Old 04-19-2012, 07:42 PM Thread Starter
how much fork oil?
How much fork oil is recommended when running the progressive 2" lowering kit? Progressive is closed for the night and I cant find anything online.
Thanks
junk runner jr is offline
post #2 of 12 (permalink) Old 04-19-2012, 10:26 PM
homeboy58's Avatar
Monotube kit for 2010 is 5oz of 15w. Progressive has install PDF's on there website.. depends on lowered, stock height or drop in springs vs. monotubes...
2010 FLTRX | Stage 1 |SE tuned |84.07 HP | 95.28TQ | Progressive 940's -1 | Progressive monotubes-2 | Performance Machine l Clearview | Cyclesmiths | Klockwerks | Hells Foundry | MCC | Corbin | J&M | Yafee| Ness | RSD l Covingtons l CustomDynamics | Garmin | Badlands |LePera | TopShop,...to be continued
homeboy58 is offline
post #3 of 12 (permalink) Old 04-20-2012, 08:56 AM Thread Starter
I looked at the pdf it does not have anything about how much fluid to use. Progressive will be open in a few hours. I'll have to wait and give them a call.
post #4 of 12 (permalink) Old 04-20-2012, 09:33 AM
HD_Shock's Avatar
Yes, it does. Mentions to use 5 oz. on the bottom of both pages 1 and 2. Here's what it says on page 2:
Pour 5 ounces of 20WT or Type H-D fluid in each fork, pausing to stroke the assembly to get the fluid into the outer fork slider. Failure to do this will cause the required amount of fluid to overflow (see figure 4). This fluid is just to lubricate moving parts and has no effect on the actual damping action of the sealed Monotube cartridge fork insert.
Here's the PDF
http://www.progressivesuspension.com...FLT%20Inst.pdf
-phil
2011 FLTRX 103
HD_Shock is offline
post #5 of 12 (permalink) Old 04-20-2012, 11:53 AM Thread Starter
Thank you that is a totally different document than what I had found.
post #6 of 12 (permalink) Old 04-20-2012, 12:00 PM Thread Starter
I see the difference the doc you refenced is for the monotube kit. I am running the normal lowering kit (not the drop in kit) PN 10-1561. I called Progressive they said to run the normal amount called for by Harley. I was over flowing a bit last night when I was working on it. The tech suggested cycling the suspension few times and topping it of.
I will update this thread tonight just incase someone else has the same question and does a search.
post #7 of 12 (permalink) Old 04-20-2012, 12:46 PM
HD_Shock's Avatar
Ah! That makes a huge difference - sorry, didn't mean to lead you astray. You definitely need more than 5 oz with a damper style fork. The oil for the monotube kit is for lubrication only.
-phil
2011 FLTRX 103
HD_Shock is offline
post #8 of 12 (permalink) Old 04-20-2012, 02:05 PM
DED HD's Avatar
Did you measure how much oil you took out?
That would be the best way to find out.
Manual says like 10.7 oz i believe. so probably anywhere around 9.5-11 oz. Just gotta make sure you got all of the old oil pumped out. Did you pump the front end when you were draining to get all the oil out. sometimes, air pockets will hold some of the oil from coming out.
'10 Red Custom:
DED HD is offline
post #9 of 12 (permalink) Old 04-20-2012, 02:12 PM Thread Starter
Oh yes it was dry as a bone. They were fully disassembled and poder coated. I only got about 8 oz in last night and it ran over. I guess I should have cycled the suspension. I'll try that tonight.
I don't have a manual but I asked at the dealership the other day and was told 11.1 oz. When it ran over I was concerned maybe the 11.1 was the total for both forks.
I really need to by a manual...
post #10 of 12 (permalink) Old 04-20-2012, 02:38 PM
DED HD's Avatar
what year bike do you have?
Yes, Service Manual should be the first thing to purchase if you do any wrenching on your bike.
MadRacer likes this.
'10 Red Custom:
DED HD is offline
15 how much fork oil? RDCRIS *General Road Glide Discussions/Pictures 5 03-23-2016 11:52 AM
Decel popping - how much is too much? Methos1979 Intake and Exhaust 18 10-14-2015 04:58 PM
How much fork oil for stock forks? JayZed75 Suspensions 5 03-11-2014 09:45 PM
How much noise will too much runout cause? thedrill Engine Related 18 02-27-2014 03:52 PM
How much is too much...or is there such a thing? Chaz Audio 6 09-26-2012 03:49 PM
