2008 stock height - Road Glide Forums
post #1 of 12 (permalink) Old 04-20-2012, 11:55 PM Thread Starter
hognut's Avatar
Question 2008 stock height
I have a 2008 RG I purchased from a private party. I think the bike has been lowered by the previous owner. I have to lean the bike to the right to get the kick stand down and I drag it on left turns. The front shocks "bottom out" with a solid bang on small bumps etc while riding. I took the bike to Biggs HD in San Marcos, CA and they said there is no way to determine if the bike has been lowered. Is there anyone who has an 08 with stock suspension that can give some measuring points to check my RG? Thank you for any help. Gary C
hognut is offline
post #2 of 12 (permalink) Old 04-21-2012, 05:27 AM
If you have them, check with the owners manual and or service manual. They should be able to tell you the factory seat height. Heres a link for the 08 specs http://www.motorcycle-usa.com/23389/...de---FLTR.aspx
post #3 of 12 (permalink) Old 04-21-2012, 09:10 AM
Xaran's Avatar
I can measure later today but the rear shocks should measure 13" eye to eye for a standard Rg and 12" eye to eye for a custom (factory lowered) anything less is defiantly lowered. Also look at the shock mount to the swing arm it should bolting the swing arm if their is a plate with 2 or 3 mounting holes on the swing arm it has lowering kit and has also been lowered. For the fork look at the cow bells ( upper fork sliders) a stock height their is about 2-3 inches of lower fork showing before it tapers down, when lowered the cow bell is almost down to where the fork narrows. Stock ground Clarence is about 5 inches
Post a picture it's easy to tell
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #4 of 12 (permalink) Old 04-21-2012, 11:05 AM Thread Starter
hognut's Avatar
Thank you ralf75, I do not have the owner or service manuals yet. Thank you for the link. I will check the seat height tonight. - Gary C
hognut is offline
post #5 of 12 (permalink) Old 04-21-2012, 11:10 AM Thread Starter
hognut's Avatar
Thank you Xaean, That is exactly the info I needed. I do not understand why the dealer could not have given me that information. I will check the measurements tonight. I will try to post a picture other than my avatar. - Gary C
hognut is offline
post #6 of 12 (permalink) Old 04-22-2012, 02:16 PM Thread Starter
hognut's Avatar
Here is a picture of the front fork. I can not see a taper but here is the measurement from cow bell to axle.
hognut is offline
post #7 of 12 (permalink) Old 04-22-2012, 02:58 PM
skratch's Avatar
its definitely been lowered. mine is 13-1/2 from the bottom of the cowbells to the center of the front axle.
check your rear shocks as well, i bet you either have lowering blocks or shorter than 12'' shocks as well.
skratch is offline
post #8 of 12 (permalink) Old 04-22-2012, 03:16 PM Thread Starter
hognut's Avatar
Thank you skratch. The rear shock was a little less that 13". I am not sure what lowering blocks look like, but i will lift the bike up to get a better look tomorrow. Ride safe. Gary C
hognut is offline
post #9 of 12 (permalink) Old 04-22-2012, 06:16 PM
skratch's Avatar
lowering blocks are easy to tell if you have them on. look at the lower shock mounting bolt. if it goes to a plate that bolts to your swingarm, you have lowering blocks. if it just goes to the swingarm directly, then you don't.
skratch is offline
post #10 of 12 (permalink) Old 04-22-2012, 11:34 PM
calgaryglide's Avatar
If the dealer service dept says they can't tell and you find out from folks on this forum what is correct, I would not take the bike back to that dealer.
Any Harley dealer should be able to tell if a bike has been physically altered from stock, if they can't their not worth doing business with.
2019 FLTRU, Tyggr
calgaryglide is offline
Ape hanger height and your height? Busted1 Controls & Handlebars 196 01-21-2018 02:57 AM
Ape Hanger Survey - Your Height & Bar Height JDisMe Controls & Handlebars 54 05-25-2017 01:43 PM
2008 stock with Feuling 525 reaper cam stock header Rush mufflers 1.75 baffle DragoBikeWorks Dyno Results 6 09-13-2012 05:19 PM
ape height and body height barbell01 Controls & Handlebars 22 03-28-2012 10:35 PM
Stock RGU WINDSHIELD HEIGHT ?? b104396 Windshields 6 07-12-2011 10:39 AM
