Who's installed Progessive Drop-In Springs on their RG? - Road Glide Forums
post #1 of 18 (permalink) Old 04-23-2012, 09:08 AM Thread Starter
I just ordered a set of the Progressive "Drop-In" springs (10-2003) for my 2009 RG. I'm looking to drop the front 1" to match up with the 1" drop from a set of Progessive 940 rear shocks.
I'm looking for a little help from those that have done the install on their RG.
First, what's the installation configuration for a 1" drop. There seems to be a few different answers to that question from reading the postings here and nobody seems to think the Progressive instructions are that great.
Second, what tools did you need and how did the install go? I really don't want to drop the tubes out of the bike (hence why I chose the "drop-in" approach) but it seems it's a little tight inside the fairing to get the tube caps off once you get the instrument cluster off.
Thanks in advance for your help.
J.D.
jdbaker is offline
post #2 of 18 (permalink) Old 04-23-2012, 09:15 AM
ameleo's Avatar
You have to drop the tubes from the bike, at least on an '11. Pretty simple install. Instructions were okay as long as you're good at turning a wrench. I used heavy fork oil to decrease the front end dip.
ameleo is offline
post #3 of 18 (permalink) Old 04-23-2012, 09:57 AM
tdkkart's Avatar
Originally Posted by jdbaker View Post
Second, what tools did you need and how did the install go? I really don't want to drop the tubes out of the bike (hence why I chose the "drop-in" approach) but it seems it's a little tight inside the fairing to get the tube caps off once you get the instrument cluster off.J.D.
Unfortunately the "drop-in" description is a bit of a mis-speak as you cannot simply remove the caps and drop in the springs, the tubes have to be removed to get the caps off, which means dropping the front wheel and fender.
That said, if you're going to the work anyway I highly recommend saving the extra cash and going with the the monotubes. I really like mine.
tdkkart is offline
post #4 of 18 (permalink) Old 04-23-2012, 11:01 AM Thread Starter
That just sucks......................
So nobody has been able to drop them in with tubes still on the bike?
I'm still hoping.......................
J.D.
jdbaker is offline
post #5 of 18 (permalink) Old 04-23-2012, 02:43 PM
ameleo's Avatar
J.D.
No choice, you have to remove the tubes.
ameleo is offline
post #6 of 18 (permalink) Old 04-23-2012, 07:34 PM
neuropac's Avatar
The ad is misleading on other hd models u can make the change but on the glide u will need to remove the forks. If u want the 1 inch drop u will need to cut the PVC spacer to place on top of the springs. I did the install this winter with chrome lower legs but chose the 2 inch drop to level my bike secondary to running a 21 inch front wheel. The install isn't had if you have some wrenching experience just take your time. I also chose the heavy fork oil to firm up the front end and help with frontend dive. I also purchased a shallow socket to remove the fork cap without removing the handlebars. Hope this helps I have pics posted in my garage of my bike with the 2 inch front and 1 inch rear drop.
2011 FLTRX 103
2005 Big Dog Ridgeback
1982 FXR Superglide 1340 shovel
neuropac is offline
post #7 of 18 (permalink) Old 06-02-2012, 08:40 PM
Redfish-Joe's Avatar
I just ordered a set myself. Question is what is it thats in the way to keep you from removing the caps?
Redfish-Joe is offline
post #8 of 18 (permalink) Old 06-03-2012, 08:41 AM
HD_Shock's Avatar
Removing the top cap isn't the problem - removing the bars or the tank will allow access. However removing the cap won't let you remove the springs. The cap merely secures the forks to the upper tree. The cap is screwed into the top fork PLUGS ... and it's the plugs that need to be removed. The only way to remove the plug is to drop the forks. If you remove the tank, you might be able to get by with merely lowering the forks enough to get to the plug (loosen the pinch bolt, lower the fork enough to expose the plug, tighten the pinch bolt and remove the plug), but I don't think the spring will fit through the top tree.
Hopefully, these pics will give you an idea how it's bolted up.
Cap and plug:
-phil
2011 FLTRX 103
HD_Shock is offline
post #9 of 18 (permalink) Old 06-03-2012, 08:53 AM
Makes sense now. Thanks.
post #10 of 18 (permalink) Old 06-03-2012, 01:31 PM
TheDoctor's Avatar
I installed valves in mine by just dropping the forks down as far as I could without removing the forks. It can be done.
2010 FLTRX
TheDoctor is offline
Hot Springs, Pig Trail, Eureka Springs weekend ride throttles&triggers Road Trip Discussions/Stories/Pictures 2 09-08-2014 09:49 PM
Progessive Monotube Clunk watsondog Suspensions 8 05-06-2014 08:53 PM
F/S: Progressive Drop In Fork Lowering Springs zman Sold 7 01-30-2014 08:30 AM
Progressive Drop-In Fork Springs 02 RG- Need help adrenilinecrash Suspensions 0 10-04-2013 02:44 PM
What pre-load are you running on your Progessive 940 Ultra Touring? jdbaker Suspensions 10 05-03-2012 10:39 PM
