Rear suspension woes - Road Glide Forums
post #1 of 40 (permalink) Old 04-23-2012, 09:31 AM Thread Starter
Paul's Road Glide's Avatar
So I took delivery of my RGC about 6 weeks ago and have put about 1800 miles on it so far. well, this is my first bike with adjustable air shocks and when I left the dealer, I obviously didn't know any better, but they hadn't filled the shock with any air. I found out, b/c my buddy who has a SG, after telling him the ride was rough on the rear and felt like I was bottoming out, he then got his pump and filled it up. Well, since then I have purchased my own pump and monitored to make sure no damage was done from when I rode until i was able to fill up.
My question to you, do you think riding on 0 psi damaged my shocks? The reason I ask is, even though I have filled the shocks with a range from 15 psi to 22 psi trying to find that sweet spot, nothing. I ride two up with the OL most of the time and when she is on and we hit any small insignificant bump, it feels hard. I mean, it feels like we pretty much bottom out and she comes off her seat ever so slightly. Should I take it in and have them replace those shocks? I need some help.
Paul's Road Glide is offline
post #2 of 40 (permalink) Old 04-23-2012, 09:45 AM
staush's Avatar
The owners manual shows you can have from 0 to50 psi in the shocks.Don't think you can do any harm riding at 0psi. If you have the R/G custom it is 1" lower than the Ultra and the ride isn't the softest one out there. Another deal where form is over function. My 11 custom is pretty rough over bumps also.
staush is offline
post #3 of 40 (permalink) Old 04-23-2012, 09:49 AM
laxinharley's Avatar
Fill her up! Mine sits at just under 50 all the time and I have no complaints. Even with the woman on the back. I keep mine at 48. Of course I weigh 315lbs too so that doesn't help.
laxinharley is offline
post #4 of 40 (permalink) Old 04-23-2012, 09:50 AM
Triplej's Avatar
You need more air pressure especially when riding two up. The manual calls for 40-50 PSI in the rear for two up on your scoot.
I leave mine at 50 PSI all the time for the same reason and have no issues riding solo with that air pressure.
If your shocks are holding pressure I doubt you did any damage to them.
Triplej is offline
post #5 of 40 (permalink) Old 04-23-2012, 09:53 AM Thread Starter
Ok. This is good to know. Just wanted to make sure that nothing was ruined. I had read about the 0-50 psi, but I don't recall seeing anything about prolonged riding and honestly only did about 70 miles on 0 psi. I weight 175 and my OL weighs 105. I've been told that 22psi is what I should be at. Any real world advice?
post #6 of 40 (permalink) Old 04-23-2012, 10:05 AM
Triplej's Avatar
According to the attached page from the service manual 22 PSI would be a good range riding solo with 40lbs. of luggage at your weight.
For two up give it 50 PSI and you can remove some air down till 40 PSI and see what range works best for you.
Triplej is offline
post #7 of 40 (permalink) Old 04-23-2012, 10:24 AM Thread Starter
Thanks John. will give it a shot tonight.
post #8 of 40 (permalink) Old 04-23-2012, 10:29 AM
No matter what you do to the OEM shocks, your not going to get a great ride, just good at best. I seriously doubt if you did any damage to your shocks at 0 psi, probably just have a sore butt. In the future you might want to look at getting a good set of after market shocks, or even the HD premium shocks, that will be much better than stock.
post #9 of 40 (permalink) Old 04-23-2012, 10:43 AM Thread Starter
Yeah, I'm just trying to get it good enough from having my wife beat my kidneys to a pulp everytime we hit a bump.
post #10 of 40 (permalink) Old 04-23-2012, 03:30 PM
runmanpkll's Avatar
i used to mess around with the pressure but now i just keep it at 50 psi and everything is fine.
runmanpkll is offline
2016 Road Glide Front Suspension Woes Riderdave Suspensions 32 05-06-2018 04:37 PM
My cam chain tensioner woes... Slyguy41 Engine Related 11 05-24-2014 05:59 PM
Rain Woes NORSEMAN General Off-Topic Discussions 5 07-12-2013 04:33 PM
Rear Tire Woes Harley328 Wheels and Tires 2 08-05-2012 02:54 PM
speedometer woes GliderAbe Troubleshooting for Road Glides 6 04-19-2012 10:03 AM
