Brake Question - Road Glide Forums
post #1 of 19 (permalink) Old 10-15-2014, 09:21 PM Thread Starter
AtomiCapricorn's Avatar
Brake Question
Every night, I park my bike facing downhill. Every morning, I have to pump up the front brakes. When I first get on the bike, the front brake lever can be pulled all the way to the grip. They function normally after 5-10 pumps; no codes, ABS or otherwise. What causes this?
'13 FLTRX, BBP, Vivid Black painted inner fairing, 9" Windsplitter, 14" W1 Chubbys, Get-A-Grips, Daymakers, ABS, Cruise, Security, 4 Speaker HW/Jensen HD1BT System, Fuel Moto Jackpot Header/Nightstick Exhaust, Powervision, Fueling 543 cams (95HP/104TQ). Yay, me!!
AtomiCapricorn is offline
post #2 of 19 (permalink) Old 10-15-2014, 11:22 PM
Does it do it when the bike is parked the other way? Sounds like there's air in the system. Unfortunately you'll need to take it to the dealer to have them bleed the ABS brakes properly.
post #3 of 19 (permalink) Old 10-16-2014, 07:05 AM Thread Starter
Thanks for your response!! I haven't tried parking it the other way (facing uphill), because it's difficult to turn it around. Backing up to turn around on gravel is no fun in the dark.
Shoot. Well, it's going in for 15K mile service next Wednesday anyway. I'll have them check it out.
post #4 of 19 (permalink) Old 10-16-2014, 12:37 PM
Could be a bad front brake master cylinder. It is not normal to have to pump up the brake system after the bike has been sitting.
post #5 of 19 (permalink) Old 10-16-2014, 01:18 PM Thread Starter
It's weird, for sure. It doesn't happen after sitting on a level surface for extended periods, like when I get on it after work. Only after it's been sitting on the hill...
post #6 of 19 (permalink) Old 10-16-2014, 02:58 PM
If it's still covered by a warranty let the dealer look at it. Like Ironmark mentioned it shouldn't do that no matter where or how you park
post #7 of 19 (permalink) Old 10-16-2014, 08:34 PM Thread Starter
It's probably not covered, as I changed out the handlebars, and therefore, the lines as well, a couple of months ago. Whatevs, I'll pay if I have to. 😄
post #8 of 19 (permalink) Old 10-16-2014, 08:44 PM
Sounds like the brakes need to be properly bled by the Dealer...
Let us know if that does it for you...
HeatWave is offline
post #9 of 19 (permalink) Old 10-16-2014, 09:37 PM
How did you end up bleeding the brakes when you swapped everything?
post #10 of 19 (permalink) Old 10-16-2014, 09:51 PM
93-331-29psi's Avatar
You don't need the dealer to bleed them anymore than you need them to change your oil. There are a couple inexpensive methods and both work well.
1. Vacuum bleed from the calipers
2. Gravity bleed into an old soda bottle (one per side).
I've used both methods with my bike and never had a problem.
93-331-29psi is offline
Brake Levers and rear brake pedal from 2010 FLTRX (STOCK) HUTMO Miscellaneous for Sale 4 03-03-2016 06:48 PM
Soft Brake chrome slotted Brake Pedal longrides Sold 7 05-17-2013 09:03 PM
Billet brake lever installed for rear brake HUTMO Do-IT-Yourself 1 12-27-2012 04:18 PM
Dual brake set up to single side brake Q-Hog Wheels and Tires 12 08-01-2012 12:55 PM
Changed rear brake arm now almost no rear brake? ncbeast Troubleshooting for Road Glides 4 05-30-2011 10:13 PM
