Front End Question - Road Glide Forums
post #1 of 14 (permalink) Old 10-29-2014, 09:51 AM Thread Starter
Question Front End Question
Looking to upgrade front end..Progressive mono tubes, Arlen Ness lowers and boots. My question,..is it necessary to remove the inner fairing to do this??
2013 FLTRX, FM Jackpot 2-1-2 , FM A/C, 4" Rineharts,PVw/Autotune, Arlen Ness deep cut hot Legs, Progressive mono, Detach Tour Pak, 14" Windvest, Buky 12" Malo, JM XTs and AMP
twrguy is offline
post #2 of 14 (permalink) Old 10-29-2014, 09:55 AM
RoadGlideGary's Avatar
No. Just the outter fairing, ignition switch, insturment natchel, front fender and wheel,.....
Lots of posts in suspension to assist and video too. Not hard to do if you have proper tools. Take your time!
05' SuperGlideCustom - sold
RoadGlideGary is offline
post #3 of 14 (permalink) Old 10-29-2014, 10:06 AM
No need to touch inner or outer fairing , if your just doing Monotubes & Cow bells.
post #4 of 14 (permalink) Old 10-29-2014, 10:07 AM
FastHarley's Avatar
You only need to remove your nacelle. This is me changing out the triple trees and forks on a 2011. I never touched the fairing, no need for it. There are better options available for your bike.
FastHarley is offline
post #5 of 14 (permalink) Old 10-29-2014, 10:13 AM
Did mine last winter no need to remove inner or outer fairing There is a video on you tube that pretty goog
Whitehairedpete is offline
post #6 of 14 (permalink) Old 10-29-2014, 12:22 PM Thread Starter
Talking Thanks!!
Once again,, THANKS GUYS!!!!
I will be doing this project on Saturday. I will upload pics as well.
twrguy is offline
post #7 of 14 (permalink) Old 10-29-2014, 10:45 PM
Wow that's a sweet looking setup you have... Very nice
2012 FLTRX
Sideways is offline
post #8 of 14 (permalink) Old 11-10-2014, 12:55 PM Thread Starter
Talking Front End Complete
Finally got all of my parts and completed the install on Saturday. I will be posting pictures and video as soon as I get it edited together. I only ran into one minor snag. The left side bottom Allen bolt stripped when I tried to remove it. I had to go to 3 different places to to get an extension and easy out that would fit in the small hole at the bottom of the fork. I SHOULD HAVE STARTED AT HARBOR FREIGHT!! I could have saved myself 3 hours of driving around. Even the replacement bolts I got from the dealer seem a little shallow so if you are doing this be careful to get a good bite straight on so you don't have the headache I got Without that snag this would have been a 3 hour job max!! Everything else was straight forward as posted on other videos. No problems with fairing at all, only instrument cluster needs to be removed. I was able to get the fork cap bolts off with a crescent wrench. My handle bars did not allow for use of the 1 3/8" socket ( I could have moved the bars but the crescent worked fine) I am going to show some of the tools I used and made in the install video. Again thanks to this Forum for reducing the "pucker" factor in tackling these projects!!!
twrguy is offline
post #9 of 14 (permalink) Old 11-10-2014, 05:43 PM Thread Starter
Smile Video and Pics as promised
twrguy is offline
post #10 of 14 (permalink) Old 11-10-2014, 06:40 PM
Nice job, looks great. I wonder how those sliders will hold up to nicks & chips from road debris. I was going to go powder black on the sliders and those cow bells but decided not to , due to nicks and chips.
Front end Question Lunchboxx Suspensions 3 03-17-2015 06:03 PM
Chrome front end question LNWLF *General Road Glide Discussions/Pictures 8 11-07-2013 02:03 PM
Front end question Bigdutch Suspensions 3 12-02-2012 05:39 PM
front wheel or front end jonessigns Troubleshooting for Road Glides 0 05-07-2011 04:02 PM
Front End Question kirbo Suspensions 3 03-11-2011 10:27 PM
