Fork question - Road Glide Forums
post #1 of 5 (permalink) Old 05-09-2012, 01:07 AM Thread Starter
Fork question
Ok, so I'm wrapping up my build tomorrow and while mocking the front fender up today I noticed what without the wheel and axle on my forks can both rotate clockwise and counter clockwise. The bolts up top are secure and I tightened the pinch bolts just above the fork cans. Is it normal for the lower forks to have some play in them if you try to rotate one way or the other? Obviously one the fender is on and the queen and axle they don't spin. I just want to verify that this is normal before I take my maiden voyage tomorrow. Also, I used 1/4 rope taped to the tire to establish the clearance between tire and fender when mocking up as per yaffes directions for the fender. Now that the fender is on and rope is off I notice the clearance in the front of the fender has lessened. Is this going to cause problems? I have less than a quarter inch space now in the front but more towards the top and rear.
SGT_Rob
The very essence of leadership is its purpose. And the purpose of leadership is to accomplish a task. That is what leadership does–and what it does is more important than what it is or how it works.
~Colonel Dandridge M. Malone
SGT_Rob is offline
post #2 of 5 (permalink) Old 05-09-2012, 01:16 AM
JJSW1283's Avatar
Yes they can rotate. Use your axle to get them squared up, then take it back off. Then you can go ahead with putting fender back on, etc.
JJSW1283 is offline
post #3 of 5 (permalink) Old 05-09-2012, 01:19 AM Thread Starter
Thanks for the reply. I was having a helluva time! Everytime I took off the axle and went to put te tire on the damn things would rotate out! Finally got it all done now I'm worried my fender ended up too close to the tire. If I have to bore out the holes I drilled I'm afraid the may show above the mounting points onthe fork
SGT_Rob
SGT_Rob is offline
post #4 of 5 (permalink) Old 05-09-2012, 01:25 AM
JJSW1283's Avatar
You could just leave the axle on and put your fender on, then take it off.
JJSW1283 is offline
post #5 of 5 (permalink) Old 05-09-2012, 01:30 AM Thread Starter
That's ultimately what I ended up doing. I take can the easiest jobs and make them quests!
SGT_Rob
SGT_Rob is offline
Ricor Intimindators and Fork Question Vinchenz Suspensions 8 05-13-2013 09:33 PM
Question about fork seals Sealdoggy Suspensions 3 04-21-2012 12:44 AM
Fork legs question fugly1 *General Road Glide Discussions/Pictures 9 12-18-2011 09:08 AM
Fork Install Question METALKAT Suspensions 3 02-06-2011 12:06 AM
Fork Change Question Roadie09 *General Road Glide Discussions/Pictures 1 12-04-2010 08:31 PM
