Ohlins 3-3 shocks - Road Glide Forums
post #1 of 6 (permalink) Old 11-18-2014, 09:03 AM Thread Starter
SmokeyJoe's Avatar
Ohlins 3-3 shocks
Does anyone know if the Ohlins shocks setup for a 2010 Ultra classic, will fit on a 2012 Road Glide CVO?
The measurements are 12 3/4 to 13 9/64 stroke of 3 1/32
SmokeyJoe is offline
post #2 of 6 (permalink) Old 11-18-2014, 10:58 AM
They will fit, and if it's for the same person, the set up should be close. Only thing I'm not 100% on is the height....... may be 1" off, hopefully someone who knows that will chime in.
post #3 of 6 (permalink) Old 11-18-2014, 11:53 AM Thread Starter
SmokeyJoe's Avatar
The guy I am getting them from got them from Motorcycle Metal, and he weighs the same as I.
post #4 of 6 (permalink) Old 11-18-2014, 12:28 PM
HD2012CVO's Avatar
Email Howard at motorcycle metal - he'll be able to tell you.
My mods: 12 Buky Malos, Buky engine guard, BR Customs bag guards, Custom Dynamics driving lights, running/directional lights, DayMakers, Precision Billet Darkside rider and passenger floorboards, foot brake, shifter, Willie G lic plate bolts as glovebox knobs, GADS products, saddlebag gun safe, Zumo 665, Iron Aces mount, Madstad 11" and 13" shields, Ohlins #6.
HD2012CVO is offline
post #5 of 6 (permalink) Old 11-18-2014, 12:34 PM
tj316's Avatar
they will fit , they have a 77mm stroke so you will set your sag at 1" , they have an adjustable eye in the bottom , set at the lowest setting they are 12 3/4" so with a 1" sag you would sit at 11 3/4" at that setting
tj316 is offline
post #6 of 6 (permalink) Old 11-18-2014, 04:38 PM
mocotom's Avatar
If he had them set correctly there should be no more than fine tuning for your preference of ride.
2005 RG 98cu in
USMC 1968-1972
mocotom is offline
Ohlins HD 357 vs Ohlins HD 022 mach65 Suspensions 8 09-08-2015 11:54 PM
Ohlins HD357 "Road Officer" shocks McGruder Suspensions 9 03-20-2015 05:22 AM
Ohlins #6 review & shocks 101 tj316 Suspensions 17 06-27-2014 04:17 PM
Ohlins rear shocks for 2012 CVO riptilyaflip Suspensions 15 07-08-2013 05:23 PM
OHLINS rear shocks THEMASTERDESTROYER Suspensions 8 01-21-2012 01:39 PM
