Mono tubes - Road Glide Forums
post #1 of 4 (permalink) Old 05-13-2012, 07:48 PM Thread Starter
Mono tubes
Bought a set of progressive mono tube lowering cartridges ..gonna go to a 21. Should I go 1" or 2". Going to run a 21" soon just not right now. I ride a lot of 2 up...should I go 1 or the full 2 with both springs on dampener .Any c clips on 2". If 1" how many c clips work the best? What weight fork oil. Thanks 2010 road glide with low profile shocks on rear
Shayne
darty411 is offline
post #2 of 4 (permalink) Old 05-13-2012, 11:58 PM
Xaran's Avatar
I'm running them at stock height but there have been threads recently about them with 21s and the general opinion was to go the full 2" lower. To level out the bike.
But it will loose a little in the ride for 2 up if you are at 2" lower. Also be careful and check fender clearance at 2" lower I've read where some have hit the fender on the frame or engine guard when 2" lower and it bottoms.
Xaran
Previous HDs
2004 Road King Custom - SOLD
Xaran is offline
post #3 of 4 (permalink) Old 05-14-2012, 07:50 AM
HD_Shock's Avatar
I just installed a 21in wheel and the lowered monotube kit. I went with a 1in drop and no regrets. A 21in wheel with a 120/70/21 tire will result in a 1 1/4in higher ride height over the stock 18in wheel/tire so the one inch drop brings the ride height back down close to where it was.
I had the same concern about running the lowered monotubes with the stock wheel. Some who have done it say it's not an issue. Me, I just figured it was a good excuse to get new wheels!
-phil
2011 FLTRX 103
HD_Shock is offline
post #4 of 4 (permalink) Old 05-14-2012, 09:12 PM
Mr. E's Avatar
I lowered my RG 2" and kept the stock wheels. I've only put 100 miles on it since the change. All 2up miles. So far no problems with clearance.
'12 FLTRX BBP
'03 Deuce Black/Silver
'95 Sportster Blue/Silver
'89 Sportster Turquoise /Cream
'79 Honda CB750F Black
'78 Honda CB400 Red
Mr. E is offline
Standard Ride Height Mono Tubes preload SlowGuy Suspensions 8 03-17-2014 11:17 PM
Progressive mono tubes Brianu1 Suspensions 10 03-11-2014 11:21 PM
mono tubes craig demel Suspensions 17 01-07-2014 11:02 AM
Air ride and Mono Tubes installed Sikk1 Suspensions 13 09-15-2012 08:23 PM
21" wheel with -2" mono tubes SIC_26 Suspensions 0 06-04-2012 06:19 PM
