Fork cap bolt removal - Road Glide Forums
post #1 of 31 (permalink) Old 05-14-2012, 02:54 PM Thread Starter
hognut's Avatar
Question Fork cap bolt removal
I need some help in removing the front fork cap bolts on my 2008 RG. I have removed the instrument and switch covers and do have the outer faring removed. How do I get access to the top of the bolts? do I need to remove the inner faring? Is there a special wrench / socket required or just an open end wrench? I have searched other posts and have not seen a comment on getting access to the bolts. Thank you for any assistance. - Gary C (hognut)
hognut is offline
post #2 of 31 (permalink) Old 05-14-2012, 03:11 PM
JayKS's Avatar
I used an impact wrench and a 1-3/8" socket. You can probably bust it loose without an impact, but it sure comes in handy.
Cheers. -Jay
JayKS is offline
post #3 of 31 (permalink) Old 05-14-2012, 03:24 PM
homeboy58's Avatar
I used a 1 3/8 socket ,no impact..with a 4"extenstion to get in there.
2010 FLTRX | Stage 1 |SE tuned |84.07 HP | 95.28TQ | Progressive 940's -1 | Progressive monotubes-2 | Performance Machine l Clearview | Cyclesmiths | Klockwerks | Hells Foundry | MCC | Corbin | J&M | Yafee| Ness | RSD l Covingtons l CustomDynamics | Garmin | Badlands |LePera | TopShop,...to be continued
homeboy58 is offline
post #4 of 31 (permalink) Old 05-14-2012, 03:57 PM
faceracer's Avatar
Send a message via Yahoo to faceracer
Big open end craftsmen wrench
I just had mine off. I did have the gas tank off which gives you more room for the wrench. If you removed the ingnition switch per the manual the forks are locked. Once I had the covers all off I reassembled the ingnition sw. so I could turn the forks. Good Luck! FACE
faceracer is offline
post #5 of 31 (permalink) Old 05-14-2012, 04:02 PM
HD_Shock's Avatar
They shouldn't be so tight you need an impact. I also had the tank off - removed them easily with a crescent wrench.
-phil
2011 FLTRX 103
HD_Shock is offline
post #6 of 31 (permalink) Old 05-14-2012, 04:24 PM
JJSW1283's Avatar
+1 on the adjustable wrench. We say adjustable down here, I had to google what a crescent was.lol
JJSW1283 is offline
post #7 of 31 (permalink) Old 05-14-2012, 04:25 PM Thread Starter
hognut's Avatar
Thank you all for the help. I guess the answer is to remove the gas tank. I did not see in the posts I found a mention of removing the gas tank. I will do some google searches and look on you-tube for a how-to to remove it. I may need some help when it comes time to put it all back together. I already know I messed up removing the ignition and it is out of sync - Gary C
hognut is offline
post #8 of 31 (permalink) Old 05-14-2012, 04:40 PM
JayKS's Avatar
Well, yeah, but if you got an impact laying there on the bench, how can you resist it? Zinggg...zing.zing...zinggggg!!
JayKS is offline
post #9 of 31 (permalink) Old 05-14-2012, 05:38 PM
skratch's Avatar
motion pro makes a nice little socket that works great for that. its really short and very shallow so there is not so much in the way. its a little pricey for $25, but i figure i've saved enough on services that i can give the bike back $25. besides, with 2 glides i the family, i know i'll use it again
skratch is offline
post #10 of 31 (permalink) Old 05-14-2012, 06:05 PM Thread Starter
hognut's Avatar
I really like the zing...zing way more than removing anything else but with less than 2" clearance above the bolt it would have to be a small wrench I cant even get my socket and drive on the nut right now. I can get an open end on but there is no clearance between tank and inside faring to turn it. If you had the clearance to use a socket and impact we have a big difference in the front ends Thanks for the suggestions as they do make me think about other ways to do it. Gary C
hognut is offline
front fork cap, is it metric? Beaver Suspensions 1 03-22-2018 06:51 PM
Front Flush Mount Axle End Cap (the bottom cap) Dmize Wheels and Tires 3 09-18-2014 05:54 PM
Front fork holder bolt threaded shaft djdenniston2014 Tech Area 1 05-15-2014 10:05 PM
Fork top bolt socket size craigp95 Suspensions 6 09-25-2013 12:56 PM
Fork cap size? THEMASTERDESTROYER Suspensions 2 09-29-2011 09:37 AM
