replacing lower legs 15 RGS - Road Glide Forums
post #1 of 13 (permalink) Old 12-13-2014, 07:07 PM Thread Starter
SE120RG's Avatar
anyone swap out your stock lower legs for chrome or black? Looking for some instructions on how to swap out the guts of the legs. How difficult is it? any special tools needed?
SE120RG is offline
post #2 of 13 (permalink) Old 12-13-2014, 07:16 PM
You can do a search on this site or google it. But, do yourself a favor & invest in a HD Service Manual before you start. Good luck.
2011 FLTRX 103 Sedona Orange
Hillglide is offline
post #3 of 13 (permalink) Old 12-14-2014, 10:33 AM
FastHarley's Avatar
same
No different than the previous years except they have no drain holes and require a different alan wrench for the damper rod bolt.
FastHarley is offline
post #4 of 13 (permalink) Old 02-10-2015, 10:25 PM
fugly1's Avatar
FastHarley ...happen to know what size allen?
fugly1 is offline
post #5 of 13 (permalink) Old 02-14-2015, 05:14 PM
FastHarley's Avatar
Impact 12mm hex socket
12mm but it must be Total Length: 79mm long or more. On e-Bay they are around $10. Another Sunex Tools (SUN26496). I bought a one piece impact 1/2" drive Grey Pneumatic 29126M that is 6" long. I use either an electric or air impact to take them off ONLY, never use an impact to put them on. It works well for all & is cheap.
post #6 of 13 (permalink) Old 03-01-2015, 06:52 PM
Sethjamto's Avatar
How'd your install go? Based on your screen name, I'm assuming it is you I just bought your stock legs from on the other website. As soon as they come in I'll be running them down the road to my powder coater and will be doing the swap after that.
Did you have to buy any of the "special" tools the manual recommends? I just read it and it mentions a couple of tools. Didn't know if I could get away without them though.
2015 Denim Black FLTRXS
14" Vindikta's - Rinehart True Duals - SE Heavy Breather Elite - Screaming Eagle Pro Super Tuner - King Tour Pak - 85.45hp / 104.41tq
Sethjamto is offline
post #7 of 13 (permalink) Old 03-01-2015, 07:00 PM
HogWild's Avatar
most important tool is patience. haha
"No man is rich enough to buy back his past, so enjoy the moment"
HogWild is offline
post #8 of 13 (permalink) Old 03-01-2015, 07:02 PM
Sethjamto's Avatar
I already have a loaded beer fridge in the garage and friends.
post #9 of 13 (permalink) Old 03-01-2015, 07:08 PM
RGKen's Avatar
The top cap is a 3/4" allen head but if you are just changing the lowers you won't need to remove it. Also 1 and 1/2" PVC pipe slit lengthwise was really tight to seat the seals so I used a 2" piece of PVC 24" long and didn't have to put the slit in it.
2018 FLTRXS
RGKen is offline
post #10 of 13 (permalink) Old 03-01-2015, 07:17 PM
Sethjamto's Avatar
Thanks for the tips. I'm replacing the lowers and upper slider covers.
Replacing Tires on 16 RGS- Metzler or Dunlap? scottrgs Wheels and Tires 15 04-22-2018 09:54 AM
lower legs 2bagger Suspensions 2 03-10-2011 06:55 AM
New lower legs auntnee *General Road Glide Discussions/Pictures 2 01-30-2011 08:01 PM
lower legs 2000up on a 99? rg201 *General Road Glide Discussions/Pictures 1 07-21-2010 05:35 PM
PC lower legs sharkey1250 Aftermarket Accessories 1 02-03-2010 09:28 PM
