Scrape Reduction Efforts - Road Glide Forums
post #1 of 17 (permalink) Old 05-21-2012, 11:01 PM Thread Starter
bikepsych's Avatar
Greetings,
Not sure if its possible or not, but what have you all been doing to keep from scraping the floor boards when aggressively riding in twisties? (Please don't say slow down). Is there a way to gain some ground clearance for these? They handle so well all the way to the scrape. Air suspension aired up to 45 pounds.
Thanks in advance.
BG
bikepsych, 2017 RoadGlide Ultra
Supertrapp Fatshots, SE A/C, 107 2 114 kit
bikepsych is offline
post #2 of 17 (permalink) Old 05-21-2012, 11:33 PM
I replace my floorboard pans once a year. that's my fix. some times I find them cheap on eBay other times the stealer takes my money. It's kinda strange but I like the sound. :-)
2011 Sedona Orange FLTRX, 124" S&S, D&D Boarzilla, 66mm Thottle Hog, Streched and Custom
piesik650 is offline
post #3 of 17 (permalink) Old 05-21-2012, 11:58 PM
Just consider them wear parts and don't worry about it!!!
Dfwhockey17 is offline
post #4 of 17 (permalink) Old 05-22-2012, 12:08 AM Thread Starter
bikepsych's Avatar
All that replacing the "wear parts" will do is reduce my ground clearance again after all that work grinding off the parts that touch down first. Still doesn't help my initial problem of not having enough ground clearance in the tight stuff.
post #5 of 17 (permalink) Old 05-22-2012, 12:18 AM
tdkkart's Avatar
I just wish I could find a corner sharp enough to drag the boards.........
tdkkart is offline
post #6 of 17 (permalink) Old 05-22-2012, 12:25 AM Thread Starter
bikepsych's Avatar
Head on up to Dubuque, then over to Galena. There are a few roads there that will get you going. Alternatively, come on out here,,,we've got plenty of scrapers. Mulholland, Hwy 33, Hwy 2 and Angels Crest.
post #7 of 17 (permalink) Old 05-22-2012, 01:09 AM
Ditch the air suspension and go over stock. 13-1/2" P-S 440's for instance.
Jeff
akjeff is offline
post #8 of 17 (permalink) Old 05-22-2012, 02:02 AM
Or go to a true air suspension like legends and you can jack up the rear for the twisites and lower it to something more comfortable for the not so technical stuff. The best part is you can adjust it on the fly....
post #9 of 17 (permalink) Old 05-22-2012, 10:16 AM
DED HD's Avatar
If you have lower shocks or Footboard spacers on your bike, you will scrape sooner. Just look at my footboard mounts:
'10 Red Custom:
DED HD is offline
post #10 of 17 (permalink) Old 05-22-2012, 10:24 AM
JJSW1283's Avatar
Attachment 12213
Scrapin made them contrast cut!
JJSW1283 is offline
For those that scrape footboards religiously, I have a question Gadgetech *General Road Glide Discussions/Pictures 10 12-20-2011 08:25 AM
Monster Ovals, anyone ever scrape em? RIDERED67 Intake and Exhaust 20 09-27-2011 11:47 AM
