Progressive Monotube question - Road Glide Forums
post #1 of 3 (permalink) Old 01-03-2015, 02:51 PM Thread Starter
dvanlue's Avatar
I had monotubes in my bike during a front end collision that bent the fork tubes. It looks like the gas shock portion is straight and undamaged but the rod that extends from the shock has shifted where it is connected to the shock rod causing the assembly to look bent. It appears that it may just be a press fit or glued based on how it moved. I'm thinking that if I can straighten this attachment point that they will be fine. It seems to me that this joint is always in compression after it is installed. Does anyone know how this is attached or have any experience straightening a monotube? Let me know your ideas. THX
2008 FLTR Candy Red Sunglo, S&S106, S&S push rods, Dragos 580 cams, Stage 2.5 heads, ported throttle body, Power Vision, Fuel Moto A/C, Aim lock up clutch, Dragos true duals, HogPro 21/18 Apollos, Ness hot legs, Native Customs cow bells.
2015 FLTRUSE Two tone blue.
dvanlue is offline
post #2 of 3 (permalink) Old 01-03-2015, 07:04 PM
dnschmpn's Avatar
Monotubes are relatively cheap. I would replace and not take the chance.
Enjoy the Ride!
2013 RGU in Big Blue Pearl
dnschmpn is offline
post #3 of 3 (permalink) Old 01-03-2015, 07:09 PM
Jetman's Avatar
You could call Progressive - their customer service has always been very helpful for me.........Personally - I'm with dnschmpn..........I'd be replacing them. $300.00 in the scheme of things is a droip in the bucket to ensure your saftey...JMO......
2012 - Big Blue Pearl
Heavily Accessorized.....
Jetman is offline
Progressive Monotube Question NORSEMAN Suspensions 10 02-21-2013 09:18 PM
Progressive Monotube Question Willy_B Suspensions 35 12-15-2012 10:43 PM
Progressive lowered Monotube question easyrider9809 Suspensions 11 05-23-2012 12:00 AM
Progressive monotube on RGU jupiter Suspensions 11 09-08-2011 09:58 PM
Progressive Monotube bigbrainbob Suspensions 12 04-23-2011 04:32 PM
