Changing Fork oil ? - Road Glide Forums
post #1 of 3 (permalink) Old 05-30-2012, 12:27 AM Thread Starter
Big Moke's Avatar
Changing Fork oil ?
Hey guys, I heard there is a way to drain and REFILL the fork oil thru the drain plug on the bottom of the fork tubes. Has anybody used this SIPHON method before? Can you direct me to a tutorial or video that shows how its done and what kind of tool is needed?
As always, any help would be greatly appreciated. I cant afford to pay the STEALERSHIP for 4 hours of labor every time I wanna do this.......
Some days your the Dog, Some days your the Hydrant !
2011 FLTRX 103: Blacked out Rinehart True Dual Extremes, Screamin Eagle Intake, Road 6 Customs 9inch mini`s, Screamin Eagle performance clutch spring
Big Moke is offline
post #2 of 3 (permalink) Old 05-30-2012, 01:15 AM
Bite the bullet and pop in a set of Progressive Monotubes.... not only do they work great but you wont need to service the forks again. I got a set off Ebay for $245 and installed them myself in about 2 hours. (3 hours if you count figuring how the fairing comes off and goes back on)
Fog Shark is offline
post #3 of 3 (permalink) Old 05-30-2012, 05:24 AM
tmd
The service intervel is like 50,000 miles before you change the oil. Even then 4 hours is a bit much. Take the covers off around the steering head, remove the cap, and refill from there. Heck I changed out my lowers to chrome ones in less than that amount of time.
tmd is offline
Changing oil.. on your own do you break the warrenty? HawaiianBuddha69 Fluids and Lubricants 5 08-18-2017 02:38 AM
Changing your oil. Engine warm or cold? Minivend *General Road Glide Discussions/Pictures 19 04-14-2013 12:11 AM
Anyone know of a good write up on changing fork lowers and cowbells???? leeinmemphis *General Road Glide Discussions/Pictures 11 05-19-2012 09:20 AM
Lower your oil temp by changing your oil...??? dklanecky Do-IT-Yourself 14 07-07-2010 10:29 PM
Changing oil in late model touring bikes 96349 Do-IT-Yourself 2 03-23-2010 10:29 PM
