air pump alternatives? - Road Glide Forums
post #1 of 11 (permalink) Old 06-01-2012, 09:36 AM Thread Starter
DWyellowRG's Avatar
Are there any good alternatives to the HD suspension pump? I don't mind buying the HD one if its the best, but I would rather save some coin if there is another option.
DWyellowRG is offline
post #2 of 11 (permalink) Old 06-01-2012, 11:25 AM
CHAINSAW's Avatar
Go to walmart and get a bicycle pump. The one I used to carry was only $9 and had a built in gauge. Worked great,.. but now I carry a small portable air compressor incase I gotta air up tires.
Such is the rule of honor.
CHAINSAW is offline
post #3 of 11 (permalink) Old 06-01-2012, 11:36 AM
h-donut's Avatar
are you talking one of those home depot units they had a few weeks back?
beginning to run out of saddlebag room quick.
2010 FLTRX- r o a d g l i d e
h-donut is offline
post #4 of 11 (permalink) Old 06-01-2012, 12:04 PM
Mcrider996's Avatar
+1 on this.....I've used my elec pump for more than shocks since I started carrying it.
2009 FLTR 96", Custom denim Black paint.........always a work in progress
2004 1200C (hers)
"I'm not good........but I'm fast....."
Mcrider996 is offline
post #5 of 11 (permalink) Old 06-01-2012, 12:06 PM
arkieglide's Avatar
I use the shock pump from my mountain bike shocks. I don't know how it compares in price but is the same design as HD pump.
2011 RG Ultra Brilliant Silver Pearl
arkieglide is offline
post #6 of 11 (permalink) Old 06-01-2012, 03:53 PM
I have a Progressive brand pump. It's cheaper than the HD pump and exactly the same. Get the one with the 0-60 pound gauge.
Monkeyman is offline
post #7 of 11 (permalink) Old 06-01-2012, 05:16 PM
mastergunnera8's Avatar
Here's the one I got:
http://www.amazon.com/Topeak-Pocket-.../dp/B000FIAUN4
It works great. you can use any pump that is made for mountain bike shocks...
Mine is easy to use; has a screw on primary end that doesn't push down on the valve stem, and a secondary screw in that compresses the valve once the primary is seated; once done pumping, unscrew the secondary, sealing the airflow, then unscrew the primary to remove from the stem
mastergunnera8 is offline
post #8 of 11 (permalink) Old 06-01-2012, 08:14 PM
jimmyray11349's Avatar
walmart as Chain said. Bell Airstrike 1000 bicycle pimp. $10. works great.
87hp 101tq
Baggershield
Harley Hammock-Adj.Back Rest
Saddlebag Bra
Hidden Multi-Color LEDs
Jagg Fan Assisted Oil Cooler
jimmyray11349 is offline
post #9 of 11 (permalink) Old 06-01-2012, 10:49 PM
Laconia's Avatar
I put Ohlins #6's on and tossed the pump in a drawer!!
2017RGS, Vel Red, Stage IV, HD Performance Exhaust, HD Tuner, SuperShox Premium 14", HD Tall Boy Bars, Lepera Daddy Long Legs, HD Cool Fan, EZ-Up, 15" Smoke Windshield, Rear Saddlebag Guards, LED Lighting,Passenger Floor Boards, Whim,
Laconia is offline
post #10 of 11 (permalink) Old 06-04-2012, 03:27 AM
Pump
Yes, buy one from Progressive Suspension, they make the HD one and yes, theirs is less expensive!
Sidecar Cycles is offline
2015 RG Handlebars - alternatives?? Buiceman Aftermarket Accessories 44 05-09-2015 12:57 AM
Monotube spacer alternatives??? W_D_R Suspensions 3 01-12-2014 10:46 AM
legit and legal CABLE alternatives h-donut General Off-Topic Discussions 25 02-17-2013 11:24 PM
Poker run alternatives TracyB General Off-Topic Discussions 16 01-14-2013 07:59 PM
