Drop-in kit, is it really a drop in? - Road Glide Forums
post #1 of 11 (permalink) Old 01-13-2015, 02:21 PM Thread Starter
Transporter's Avatar
I have been looking around at reviews for the progressive drop-in kit for my 2012 FLTRU at still can't figure out if I am going to need to take off the forks, so those of you that have installed them in a 2009 and later model, was it a 30 min. install or a 3 hours?
Thank you for your time.
Transporter is offline
post #2 of 11 (permalink) Old 01-13-2015, 02:50 PM
When I did it on my streetglide (lowering for a 21" wheel) I had to drop the fork legs. I would need to look at my current bike but I'm thinking that the way they bolt up to the top of the triple tree you will have to drop the legs. If you are lowering for a wheel you will get a better feel from monotubes. I wouldn't use the drop in kit again myself. I would get springs from Racetech or monotubes.
2013 Ultra
Pics here:
rg_dave is offline
post #3 of 11 (permalink) Old 01-13-2015, 05:57 PM
Yes, they're drop in , once the forks are separated. + 1 on the mono tubes.
It's really not a bad job.
post #4 of 11 (permalink) Old 01-13-2015, 06:55 PM
tdkkart's Avatar
Yes, "drop-in" ain't really because the fork tubes have to be at least dropped down if not completely out. In order to do that, the front wheels and fender has to come loose because both will cause a bind in trying to move the fork tubes..............
Just drop them out and put in Monotubes, it's only a few minutes more to put in the whole cartridge and the ride will be MUCH better.
tdkkart is offline
post #5 of 11 (permalink) Old 01-16-2015, 11:06 PM Thread Starter
Any videos on how to install the drop-ins? Everything i can find is either drop-ins on a dyna or monotubes in a bagger.
post #6 of 11 (permalink) Old 01-17-2015, 12:48 AM
tdkkart's Avatar
Pretty much the same procedure except that with drop ins you don't disassemble the valving in the bottom of the fork tubes, or drain the oil with drop-ins.
Even with drop in you have to remove the fork tubes, remove the top caps, pull the old springs and drop in new ones.
Installation of either will be the same on a bagger or a dyna, forks are essentially the same, just more stuff in the way on a bagger.
tdkkart is offline
post #7 of 11 (permalink) Old 01-17-2015, 10:05 AM
torqu's Avatar
It's a very simple procedure.
torqu is offline
post #8 of 11 (permalink) Old 01-17-2015, 11:31 AM
You need to pull the brake calipers, wheel, and fender. Depending on how many miles you have I'd go ahead and do seals and oil.
2013 Ultra
Pics here:
rg_dave is offline
post #9 of 11 (permalink) Old 01-19-2015, 01:16 AM
I'm in the middle of doing the Monotube install on mine. It's really not bad....just take your time.
-Shark nose comes off (at least I did)
-Main ignition/tumble switch comes off
-Gauge cluster and housing comes off (housing just loose...may have to disconnect the cluster adjustment switch from main wire harness)
-Wheels, brakes, fender comes off
From here, you should have access to all the pinch bolts and main cap screw to remove legs. Little tight in some areas but you will manage.
You should have access to do the drop in kit or monotube.
this is my first time using the JS Jack....wow, what a world of difference making the job easier!!!! Made my life that much easier, I forgot how expensive it was!!!
NuckaMan is offline
post #10 of 11 (permalink) Old 01-19-2015, 02:59 AM
Bull_Duck's Avatar
Easy if you have a MC lift stand and a garage within to work. I did, followed the steps, then installed JRI on the rear. The results - way superior ride to stock. Worth the money, took my time.
Bull_Duck is offline
110 drop in, CVO w/Mods, 117 drop in Lou Dude Dyno Results 1 03-08-2017 08:59 AM
Trans oil really, really hot! August Fluids and Lubricants 6 09-12-2014 05:44 PM
I really really like my RGU . . . . RonC26 *General Road Glide Discussions/Pictures 18 09-02-2014 06:55 PM
I'm just being really really picky... BDMastiff *General Road Glide Discussions/Pictures 13 12-31-2010 11:11 PM
3'' drop kit Fireguy *General Road Glide Discussions/Pictures 12 08-18-2010 06:24 AM
