21" wheel with -2" mono tubes - Road Glide Forums
post #1 of 1 (permalink) Old 06-04-2012, 06:19 PM Thread Starter
Shark of the Month August 13
SIC_26's Avatar
I have a question for the ones that have done this already......
I just ordered my wheels and going with a 21" up front. My bike is a 2012 custom, which is lowered 1" front and rear from the factory, I'm going to be doing the mono tubes at the same time I install my wheels (in 6-8 weeks) I'll be doing the full 2" drop in the front to level the bike back out after the bigger wheel goes up front. My question is......is that all there is to it, install 21" wheel and -2" mono tubes. I just don't want to lower the front another inch and install the wheel just to find out I'm going to have a clearance problem with the bottom of my trees and my fender at full compression.
Is there no need to worry about the Clarence or is there something that I'm missing here
Thanks in advance for your input/advice
Brian
SIC_26 is offline
-2 mono tubes with 21" wheel BigPoppi76 Suspensions 1 01-16-2015 10:26 PM
Standard Ride Height Mono Tubes preload SlowGuy Suspensions 8 03-17-2014 11:17 PM
mono tubes craig demel Suspensions 17 01-07-2014 11:02 AM
Air ride and Mono Tubes installed Sikk1 Suspensions 13 09-15-2012 08:23 PM
Mono tubes darty411 Suspensions 3 05-14-2012 09:12 PM
