Progressive Drop-in question on 2012 roadglide - Road Glide Forums
post #1 of 3 (permalink) Old 06-04-2012, 09:26 PM Thread Starter
I purchased a Progressive "Lowering" Dropin kit from the dealer and doing the install right now. Anyone know how much of the pvc spacer I need for a 1" drop and also for a 2" drop?
The instructions are about as bad as they get and no help on the website
thanks!
rxfox3 is offline
post #2 of 3 (permalink) Old 06-05-2012, 01:59 PM Thread Starter
PVC spacer question for 2012 roadglide
2012 FLHTR Progressive drop-in "lowering kit" 10-2003. I was told by tech at progressive that installing the kit with no spacer is correct for 2" drop, but the bike will probably need more preload to help if the front end is "soft" or you bottom out.... the suggested spacer length is 1/2 inch for me at 200#. He said it's not mandatory, but suggested. He also said it will only raise the bike .25 inches so your bike will still be slammed
Hopefully that will help someone out!
rxfox3 is offline
post #3 of 3 (permalink) Old 06-06-2012, 12:01 PM
dgfltru's Avatar
I installed the Progressive drop in kit on my RGU. It dropped the front end about 2". The bike rides nice as the front end dive is almost gone. I have bottomed out once when I went over a pretty big hole at a bit too much speed. I have the road glide custom rear shocks installed. I also had to put on a 1" lower kick stand. I probably could have used the kick stand angle blocks but did nto thinka bout this until I had the shorted kick stand.
2018 Road Glide Ultra, Electric Blue, Lowered Front and Rear, Heated HD grips.
dgfltru is offline
Tags
2012 fltrx , dropin , progressive
110 drop in, CVO w/Mods, 117 drop in Lou Dude Dyno Results 1 03-08-2017 08:59 AM
Drop-in kit, is it really a drop in? Transporter Suspensions 10 01-29-2015 01:22 PM
Progressive Drop In Question dennisnyhc Suspensions 7 06-06-2012 04:39 PM
Pics of my 2012 RGC CVO with 1 inch drop Progressive Monotubes Cmathias Suspensions 7 04-04-2012 10:49 PM
Progressive Drop In Front SmokinToad Suspensions 26 01-09-2012 12:33 PM
