help with monotubes - Road Glide Forums
post #1 of 4 (permalink) Old 01-24-2015, 06:23 PM Thread Starter
doctor mike's Avatar
help with monotubes
need some help here.got the forks changed out with monotubes and went to install them and neither one will go into the top triple tube.the left is about 1/4" forward and right same amount aft of top hole.what did I do wrong?
BBP ULTRA,14" FACTORY 47 BARS,DAY MAKERS,MEAN MUG,JACKPOT 2-1-2,V&H MONSTER OVALS,WOODS 222 CAMS,MACH2 AC,POWER VISION,500 WATT J&M ROKKER 6 SPEAKERS,AGITATOR RIMS
doctor mike is offline
post #2 of 4 (permalink) Old 01-24-2015, 08:35 PM
laxinharley's Avatar
Our the pinch bolts loose enough. Rubber Mallot and some good wacky up could help too
laxinharley is offline
post #3 of 4 (permalink) Old 01-24-2015, 09:06 PM
FrankieB's Avatar
After you check the pinch bolts, use a bit of emery cloth on the insides of the trees and windex the tubes.
06 RK
11 RGU
FrankieB is offline
post #4 of 4 (permalink) Old 01-24-2015, 11:42 PM Thread Starter
got it,after dinner I went back out and looked at again,the bottom yoke can move independent of the top and I remember hitting the handle bars once when I walked by so I must of moved the triple tree when I did.anyway all's good,got one side in will finish up tomorrow.shiny willys chrome looks great.
Monotubes with a 21 inch front wheel 2012 RGC CVO Cmathias Suspensions 7 07-23-2012 11:18 PM
Monotubes or dropin springs Koda1975 Suspensions 8 03-08-2012 12:49 AM
Fork upgrade: progressive spring vs monotubes ilmanzo31 Suspensions 8 03-05-2012 12:37 PM
progressive monotubes THEMASTERDESTROYER Suspensions 0 03-03-2012 06:27 PM
Installing progressive monotubes how to?? jbrawkus Suspensions 6 12-12-2011 05:16 AM
