What Length shock? - Road Glide Forums
post #1 of 5 (permalink) Old 01-29-2015, 08:18 PM Thread Starter
What Length shock?
I am sure this has been asked before but need some help. I have a 13 RGC and looking to put progressive 444 shocks on. I ride solo 70% of time. I weigh 215 and wife is 120. I Have monotube -2 up front. I am on stock air shocks now. Do you think the 11.5" will give me enough suspension? I like the lowered look. Thanks for your help.
Wooddro is offline
post #2 of 5 (permalink) Old 01-29-2015, 10:32 PM
Although these shocks will give a better ride than stock, there is not much working room in a shock this short. Adjustment is critical and even a quarter turn will make a big difference.
2012 FLTRX, vivid black
sometimer is offline
post #3 of 5 (permalink) Old 02-23-2015, 10:51 AM
JRiShocks's Avatar
Our New 11" shocks will give you both. They are the "no compromise" 11" shock in the market. We guarantee you will love them! We spring and valve to your weight and application.
JRi Shocks is now focused on "customer direct" sales and we will be glad to help you.
http://www.jrishocks.com/product-cat...rley-davidson/
Marcus
JRiShocks is offline
post #4 of 5 (permalink) Old 02-25-2015, 02:38 AM
Marcus
Might have to hit you guys up for a pair. May have to wait till Sturgis unless you have a veteran or firefighter discount now
Isaiah 43:2 “When you pass through the waters, I will be with you; and through the rivers, they shall not overwhelm you; when you walk through fire you shall not be burned, and the flame shall not consume you.”
buzzkill657 is offline
post #5 of 5 (permalink) Old 02-25-2015, 02:03 PM
tj316's Avatar
my experience has been anytime you get much below 77mm in stroke length you are trading ride quality for looks , I'd look at the specs on stroke length on the 444's before deciding
tj316 is offline
length of stock shock 15 Road Glide WSL91 Suspensions 12 03-25-2018 04:23 PM
Length of Shock Lunchboxx Suspensions 3 02-14-2016 08:43 AM
2012 Road Glide Ultra stock rear shock length? privatemc Suspensions 3 09-01-2012 10:03 AM
most comfortable length shock for RG!!!!!!! gabbyduffy Suspensions 0 03-07-2011 07:45 PM
Equel Length Headers For True Dual Worth It? ncbeast Intake and Exhaust 3 09-06-2010 06:41 AM
