Tire rubbing after replacement at HD dealer - Road Glide Forums
post #1 of 7 (permalink) Old 02-19-2015, 05:27 PM Thread Starter
After taking my 04 to HD for a tire replacement the rear tire is rubbing over bumps. HD told me that because of the 18" wheel there is no tire that won't rub. I believe I have 11" shocks. There is no way that I can put my tour pack back on or ride two up. Do I need to lift the bike or did HD do me dirty?
mineman is offline
post #2 of 7 (permalink) Old 02-19-2015, 07:46 PM Thread Starter
Angry
I did some homework, HD guys made BAD recommendations!! Let the fight begin!
[/SIGPIC][/SIGPIC]Minemen do it with a bang!
mineman is offline
post #3 of 7 (permalink) Old 02-19-2015, 08:52 PM
I guess you answered your own question, but I was going to say if it didn't rub before, no way should it rub after, let us know what happens.
post #4 of 7 (permalink) Old 02-19-2015, 09:51 PM
skratch's Avatar
is it the same size tire that originally came off?
11'' shocks are 1'' shorter than the short shocks that come with the customs and street glides. maybe try 'full size' shocks?
skratch is online now
post #5 of 7 (permalink) Old 02-19-2015, 09:56 PM
Ohiobellboy's Avatar
I don't think the '04 had that wide of a tire to begin with. It's what was on my '11 which had the newer frame. I think it was wider in the rear.
A.K.A OBB
Ohiobellboy is online now
post #6 of 7 (permalink) Old 02-19-2015, 10:05 PM
FastHarley's Avatar
If this is so, than put a scissor jack or like under the bike, than jack it up.
On your bike pull the bottom of the shock out away from the swing arm so it will not interfere.
Lower the bike down until the tire touches the fender.
Measure shock mounting with a CALIPER (cheap at HF 24" aluminum jumbo > $10) top to bottom. This will give you the maximum amount your shock stroke can be. Measure the exposed shaft from shock body to bottom of the bump stop (not top), that is your total stroke.
Measure the total shock mounting bolt to mounting bolt when the shock is fully extended.
Subtract the total stroke from the shock LOA extended than if that measurement is = to or > than, the measurement between the two mounting bolts and if the total radius from axle to top of tire is too long/large than you should have not ordered & had installed the new tire size. Charts of total tire diameter(s) are available on my site as well as on the internet.
FastHarley is offline
post #7 of 7 (permalink) Old 02-20-2015, 08:10 AM
A stock 04 has 13 inch shocks, 16 inch rims front and back and 130x16 tire in the rear. If you are running a 18 inch wheel with a 11 inch shocks then tire rubbing on the top inside of the rear fender is very possible.
The 04 also uses a 1 1/8 inch drive belt and that is the reason for the 130 rear tire, when HD went to the 1 inch drive belt the rear tire went to 140.
Dealer never sent ESP Tire and Wheel paperwork to HD GlideShark Motorcycle Insurance 10 07-03-2015 08:08 PM
new tire rubbing on drive belt saccman Tech Area 7 10-24-2012 04:53 PM
21" & tire rubbing problems DemonCity *General Road Glide Discussions/Pictures 11 09-12-2011 07:53 PM
Front tire seems to be rubbing Stray Mutt *General Road Glide Discussions/Pictures 2 05-05-2011 11:29 PM
Tire rubbing alhdrider Aftermarket Accessories 0 05-24-2010 11:00 PM
