Viair mounting location idea - Road Glide Forums
post #1 of 12 (permalink) Old 02-26-2015, 07:54 PM Thread Starter
adown's Avatar
Hi everyone. I just got my air shock kit. I've been reading threads about mounting location. Why doesn't anyone mount the compressor under the engine. It fits perfectly between the engine and trans with the head on the left side pointing toward the rear, without hanging down. The hose can run up next to the shift rod between the engine case and inner primary case. Your thoughts?
adown is offline
post #2 of 12 (permalink) Old 02-26-2015, 08:00 PM
IMO there's pretty good chances of picking up debris under the engine. If you don't have ABS you can mount it under the right side cover. All I had to do was trim a piece of the empty plastic box where the ABS module would be and it fits perfectly.
post #3 of 12 (permalink) Old 02-26-2015, 10:20 PM Thread Starter
adown's Avatar
Its an Ultra. It actually will tuck up between the engine and trans nice, shielded by the pans with room around it for air to circulate.
adown is offline
post #4 of 12 (permalink) Old 02-26-2015, 11:16 PM
Hey if it fits i say go for it. Just make sure the air lines aren't near anything too hot
post #5 of 12 (permalink) Old 02-27-2015, 12:18 PM
SmokeyJoe's Avatar
Mine is between the tank and the battery under the seat.
SmokeyJoe is offline
post #6 of 12 (permalink) Old 02-27-2015, 01:23 PM Thread Starter
adown's Avatar
Ill check that area this weekend. Im going to pull the seat and start looking. Thanks
adown is offline
post #7 of 12 (permalink) Old 02-27-2015, 01:39 PM
warped's Avatar
Dirtyair had some really nice mounting brackets, this is the one i used on the rear strut bar..it can go towards the front also I'd you don't have extended bags to hide it.
warped is offline
post #8 of 12 (permalink) Old 02-27-2015, 10:00 PM
The one I offer for 09-13 touring models. $60.00 powder coated black shipped to your door. All steel and tig welded. Made in USA.
texastrendz is offline
post #9 of 12 (permalink) Old 02-27-2015, 10:05 PM
Photo:
post #10 of 12 (permalink) Old 02-28-2015, 10:19 PM
moose1's Avatar
Mines mounted like smokeyjoes it wasn't easy to get it in there but that's where arrnott suggested to put it. I took out the air temp gauge and mounted my air pressure gauge in the dash and it looks stock
2012 FLTRU vivid black
moose1 is offline
Viair 98c compressor mount texastrendz Parts for Sale 24 01-19-2015 10:10 PM
Viair In dash gauge Jwasielczyk Suspensions 2 10-03-2014 06:34 PM
What is needed to mount a Viair Compressor under the battery? 1BadGlide Suspensions 10 09-08-2014 11:17 PM
Hotel Issues - location location location DreamRider ARCHIVES-SWII LeClaire, IA 29 07-11-2012 01:40 PM
GPS Mount Location Idea! Rippest Aftermarket Accessories 3 05-01-2011 06:37 PM
