Will these work...? - Road Glide Forums
post #1 of 13 (permalink) Old 06-28-2012, 02:51 PM Thread Starter
Johnzz1420's Avatar
Will these work...?
Tryin' to lower my '07 on a budget, I came across this item to lower me an inch. Can I get away with just lowering the rear or do I have to consider front lowering springs as well?
Johnzz1420 is offline
post #2 of 13 (permalink) Old 06-28-2012, 02:56 PM
tdkkart's Avatar
They will work, alot of people use them with good results.
I don't like them because of the possibility of over stressing the factory mounts and possibly breaking them off the swingarm, but then again I haven't heard of this actually happening either.
Pick your poison..........
tdkkart is offline
post #3 of 13 (permalink) Old 07-04-2012, 11:39 AM
What brand, name on these?
jkpoppe is offline
post #4 of 13 (permalink) Old 07-04-2012, 12:26 PM
jimmyo79's Avatar
Before I went with the Arnott air ride system several years ago, I used the Burley lowering kit in conjunction with the HD 1" lowered shocks with good results. (I still have the lowered shocks, if you want to buy them at a very reasonable price, PM me) It lowered the ass @ 2.5 inches and rode OK. I ended up lowering the front end about a month later because I didn't like the nose up attitude of the bike. Hope this insight helps.
Jimmy O.
100th Anniversary Glide
No Ride like a Low Ride Glide!!
jimmyo79 is offline
post #5 of 13 (permalink) Old 07-04-2012, 12:31 PM
1BigGuy's Avatar
FYI, they will not work with most progressive rear shocks, as the bottom end of the shock is to big. These look like LA Chopper's lowering kit.
2010 FLTRX Black Denim
2007 FLSTN Vivid Black
1BigGuy is offline
post #6 of 13 (permalink) Old 07-04-2012, 02:16 PM
faststan's Avatar
Also, pay attention to the space you have between shock mount and muffler before installing these. Is there enough room?
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #7 of 13 (permalink) Old 07-04-2012, 02:47 PM
tdkkart's Avatar
And relief for the shocks in the back of the saddlebags, changing the angle of the shocks sometimes causes interference with the bags.
tdkkart is offline
post #8 of 13 (permalink) Old 07-04-2012, 05:20 PM
tmd
I had them on my 05 RG for over 30,000 miles without issue and installed them on my 11 RGU the first week I had it. I want to say the ones on the 05 were from Arlen Ness and for the 11 they are LA Choppers. Either way they were very similar and both went on without issue. Also I've nevre lowered the front on either bike and there is no noticable handling issues. Its a poormans lowering kit and they work just fine.
tmd is offline
post #9 of 13 (permalink) Old 07-04-2012, 08:47 PM
i have a set from pingel that ive used for about 22k miles without issue. they lower the rear 1" and i havent noticed any change in ride quality. as for as using them with afterrmarket shocks i couldnt tell you, i still have my stock shocks. i havent lowered the front yet either. if youre wanting to lower it more than an inch i would recommend other alternatives
post #10 of 13 (permalink) Old 07-06-2012, 07:47 PM
coryo's Avatar
I havean adjustable set on mine,I can do 1,2,or3"s. I've got mine set at 2", with stock shocks at 30 psi. Had them on a long time now and really like them, but I never lowered the front. I've got a 21" on the way so I'll probably drop the front then
Sent from my DROID RAZR using Motorcycle.com Free App
2008 105th Anniversary Copper Black FLTRI ”Duracell”, lowered, Cyclesmiths black bag extensions, Black Wild Ones 10” apes, Arlen Ness big sucker, Rush slip ons, 12” smoked LRS windshield, blacked out forks, bars, etc
coryo is offline
For anyone wanting to do engine work FLTR2008Trike Engine Related 14 11-19-2010 06:34 PM
"They work great, until they explode" FLTRI *General Road Glide Discussions/Pictures 8 10-14-2010 12:41 PM
Will a Dyna Oil Cooler adapter #26111-05 work on a RG that calls for adapter # 26151- Trikerjon *General Road Glide Discussions/Pictures 1 10-14-2010 08:40 AM
Some stuff off my 2004 RKC, that will work for RG's TobyJ Classifieds Archive (3 months old+) 4 08-04-2010 07:58 PM
Will 23" wheel work with stock fender? crazyfireman *General Road Glide Discussions/Pictures 12 07-21-2010 09:06 PM
