Kewl metal trees? - Road Glide Forums
post #1 of 7 (permalink) Old 07-03-2012, 07:26 PM Thread Starter
crazyredneck's Avatar
Kewl metal trees?
I see that kewl metal is offering a set of trees that are able to bolt on for
Running a 26" front. It keeps the rear trail near stock I would assume. Does anyone have or know about these? If I'm going to spend $1000 to buy either the trees or the trees and a neck rake kit then pay someone to rake it I would be more apt to goin the easier route that I can do myself. However I understand raking the neck would be better all around. Right? Anyone help?
2012 RG gloss black. Part of the 26" club now.
2008 fat boy. Loved her but had to let her go for the glide I've been eyeing for a while now.
crazyredneck is offline
post #2 of 7 (permalink) Old 07-09-2012, 09:45 PM
CustomGlide's Avatar
Send a message via AIM to CustomGlide
Not really much help on the Kewl metal kit but pickard also makes a bolt on set of triple trees if you want to check those out
CustomGlide is offline
post #3 of 7 (permalink) Old 07-10-2012, 08:46 AM
JJSW1283's Avatar
If I had a choice and could do it without cutting the frame I would do the 26in trees. Course, I never do anything to my bike that cant be undone. I heard from a dealer cuttin the frame will knock like 7-8k off the value of your bike. Just my .02
JJSW1283 is offline
post #4 of 7 (permalink) Old 07-12-2012, 07:55 AM Thread Starter
Pickard doesn't have a set that's straight bolt on. Kewl metals are bolt on and go. No cutting.
post #5 of 7 (permalink) Old 07-17-2012, 04:35 PM Thread Starter
Also. Will cutting the neck void the warranty?
post #6 of 7 (permalink) Old 07-17-2012, 04:55 PM
Sedona Blue's Avatar
Pickard does offer a bolt on set but it's only for a 23. As far as warranty, if everything is custom on your bike, you have nothing left to warranty. Cut the neck if your going 26, if you go 23, you don't have to cut, you can just do trees
Sedona Blue is offline
post #7 of 7 (permalink) Old 07-17-2012, 08:30 PM Thread Starter
I'm leavin the motor alone. So the incase I happen to blow that. Will that be covered?
Kewl Metal 40 degree bolt on kit 1CoolZ71 Wheels and Tires 14 01-19-2014 05:51 PM
Loud metal to metal sound in engine ??? jacksonfdny *General Road Glide Discussions/Pictures 15 09-09-2012 10:48 PM
2013 Black Pearl Metal-Flake! Neano62 *General Road Glide Discussions/Pictures 26 09-03-2012 11:57 AM
HD metal Shipping Palette BlackBetty11 Aftermarket Accessories 2 12-30-2011 11:24 PM
Damn sheet metal roofing screws!!! FLGlide General Off-Topic Discussions 14 10-06-2011 08:34 AM
