Help!! Progressive Montube install - Road Glide Forums
post #1 of 3 (permalink) Old 07-14-2012, 05:21 PM Thread Starter
Harley328's Avatar
2001 FLTR
While installing the progressive monotube kit I have a problem
The cups that sit at the bottom of the factory air shocks in side the slider..
Do u reuse them with the montube install?
Seems damn tight sliding the shock up to install the top cap of the montube ( not the cap above the triple tree.)
I have the bike torn apart of course its saturday and the progrtessive tech line is closed!!!
Thanks guys
Harley328 is offline
post #2 of 3 (permalink) Old 07-14-2012, 05:31 PM
tj316's Avatar
if you mean the ones at the bottom inside of the fork leg , yes you use them
tj316 is offline
post #3 of 3 (permalink) Old 07-14-2012, 05:44 PM Thread Starter
Harley328's Avatar
Re:
Thanks dude!!
How difficult is install of progressive Boxercop Suspensions 21 11-02-2013 07:07 PM
Progressive Install question LittleMoe Suspensions 2 04-04-2013 11:32 AM
Help.help!! Handle bar install CPY84 Controls & Handlebars 2 03-04-2013 08:31 PM
progressive monotube install questions pimpsarus Suspensions 3 12-10-2012 03:29 PM
1.5" drop with montube 06 Rider Suspensions 0 03-26-2012 04:36 AM
