Gotta Wobble - Road Glide Forums
post #1 of 10 (permalink) Old 08-08-2012, 12:40 PM Thread Starter
Gotta Wobble
I have my 05 RG with 27K. And a bad wobble that makes a shake at low speeds with light touch on bars a tight grip and no issue, smoothes out over 50. I have that goofy one sided front cannister crap in forks. probably gonna go progressive mono tubes. Also been told that because of milage my swing arm bearings could need changing. any input ? Also looking at touring link as well. Any ideas would be greatfully appreciated.
Be Well, Ride Safe, And thanks for the help.
mustangoutcast is offline
post #2 of 10 (permalink) Old 08-08-2012, 01:00 PM
FrankieB's Avatar
Pull yours wheels off and check your wheel bearings.
06 RK
11 RGU
FrankieB is offline
post #3 of 10 (permalink) Old 08-09-2012, 12:15 AM
IranAround's Avatar
X2..............
15 FLTRXS Black Denim
13 FLTRX Big Blue Pearl se IV sold
11 FLTRX se stage lV (TOTALED)
IranAround is offline
post #4 of 10 (permalink) Old 08-09-2012, 12:32 AM
Bandit's Avatar
x3.... That's what caused the wobble in mine.
2005 FLTR - 97" S&S Big Bore, Hillside Cycle Stage II Heads & Throttle Body Upgrades, S&S Rollers, Fueling Pump & Lifters, 570G Gear Drive, TTS, CFR's, Klock Werks Double Back, 104hp/106ftlbs. CB's Euro, PM Light Glide LED Kit, RC CZar Wheels
Bandit is offline
post #5 of 10 (permalink) Old 08-09-2012, 04:28 AM
I agree with all the above, and the monotube will definitely give you a better ride.
post #6 of 10 (permalink) Old 08-09-2012, 10:45 AM
With 27,000 miles it may just be that the front tire needs to be changed, while you are replacing the front tire you can check the bearings. I would doubt that the rear swing arm bushing is bad with the mileage on your bike but you should check it anyways because the rubber could dry rot and crack. The touring link is a great upgrade to do (I have one on my bike) on your bike but it is designed to eliminate the "Bagger Wobble" that the earlier touring bike may have when in a high speed curve, the touring link only stabilizes the rear swing arm and it would not help eliminate a wobble that originates from the front end. I usually get some low speed wobble from the front end when my front tire is ready to be changed.
post #7 of 10 (permalink) Old 08-09-2012, 03:47 PM Thread Starter
thanks for input will check this weekend, will keep posted
post #8 of 10 (permalink) Old 08-09-2012, 05:13 PM
A first step is to check the torque on the steering head. My 2011 shark had a real tank slapping wobble in the front end at around 35 mph until they adjusted the steering torque properly. I had no issue at higher or lower speeds. The steering is expected to make so many side to side moves when it is adjusted properly and you just release the bars. Mine was doing more than twice the number of side to side moves compared to the adjustment spec. If you have the maintenance manual, check that torque first. If not, go ask that they do it for you for a fairly small cost. I had my bike back after the warranty adjustment in about 30 minutes so the labor has to be a small charge.
Added equipment was a stage 1 HD air cleaner, a Cee Baileys windshield and a turn out boot heel guard. I also went with the BAL1 tail light MOD. You can never be too safe with lighting. Now I am riding a Vision with minor mods to give me this.
Oldman47 is offline
post #9 of 10 (permalink) Old 08-17-2012, 02:48 PM
Road Glides are known for both fall-away and wheel bearing issues. Check fall-away first.
FL64Pan is offline
post #10 of 10 (permalink) Old 08-17-2012, 03:04 PM
DED HD's Avatar
Steering head check x 1,000! Search the forum for many thread about this.
'10 Red Custom:
DED HD is offline
From the east coast to the west coast, Gotta gotta gotta go !!!!!!!! RufusBarkley ARCHIVES-SWIII St. George, UT 79 08-14-2013 09:59 PM
Winter is here and my gloves gotta go jbrawkus Clothing 9 12-13-2010 10:33 AM
I gotta tell ya... SKULLZ *General Road Glide Discussions/Pictures 0 07-18-2010 05:39 PM
gotta cut my windshield??? lowdog Windshields 6 07-11-2010 06:00 PM
The stock bars gotta go... GizmoGlide Controls & Handlebars 22 07-08-2010 05:08 PM
