rear shocks - Road Glide Forums
post #1 of 13 (permalink) Old 08-11-2012, 08:51 AM Thread Starter
rear shocks
Are there any shocks besides air suspension that can be adjusted to go from 1 up to 2up without pulling saddlebag bag to get at them? Went to adjust my air on my pos stock shocks and saddlebag just about fell to ground and pulled my saddlebag lights wiring out of wiring connection. Was thinking about the cvo shocks or progressives
hognit is offline
post #2 of 13 (permalink) Old 08-11-2012, 09:04 AM
I would believe that pulling the saddlebags would be the only way to adjust any adjustable rear shocks that are on the market. I have the saddlebag guard rails that go around the saddlebags so that takes the worry out of dropping a bag or losing a bag on the road due to pin failure. There are some that have relocated the air valve to allow better access.
post #3 of 13 (permalink) Old 08-11-2012, 09:23 AM
FrankieB's Avatar
put an air compressor on the bike
06 RK
11 RGU
FrankieB is offline
post #4 of 13 (permalink) Old 08-12-2012, 07:33 PM
Dhambrick's Avatar
I am going to putting on the EZ Air system easy to check, easy to fill. I also swap between 1 and 2 up a lot.
'12 RGU in BBP
Stuff done, more to come
'10 FLHP in Birch White (RIP)
Dhambrick is offline
post #5 of 13 (permalink) Old 08-12-2012, 08:07 PM Thread Starter
So is there a shock that you to could set without having to change every you go from 1 up to 2 up and back
hognit is offline
post #6 of 13 (permalink) Old 08-12-2012, 08:55 PM
reficul's Avatar
besides air ride i never heard of one
2012 Shark Face
One day he is gonna answer
reficul is offline
post #7 of 13 (permalink) Old 08-31-2012, 10:29 PM Thread Starter
Update: just purchased progressive 444 12" shocks, hoping to set them in between 1 and 2 up.buddy does it with his cvo shocks, so hopefully it will work. Question is if i like these , i will be selling stock 12" airs, so how do you ship the air shocks without having oil run out pf them?
hognit is offline
post #8 of 13 (permalink) Old 09-01-2012, 12:16 AM
skratch's Avatar
use a brass fitting cap that you can find at lowes, home depot, etc....
skratch is offline
post #9 of 13 (permalink) Old 09-01-2012, 10:32 AM Thread Starter
not to sound dumb but were does this brass cap go
hognit is offline
post #10 of 13 (permalink) Old 09-01-2012, 11:49 AM
skratch's Avatar
i guess a plug would be a more accurate term....
here's a pic:
skratch is offline
One set of Shotgun Shocks Shocks only*** HogPro Parts for Sale 2 02-04-2015 01:53 PM
Progressive 940 Rear Shocks landshark Classifieds Archive (3 months old+) 0 04-14-2011 12:30 AM
Rear Shocks NakedSnowman *General Road Glide Discussions/Pictures 11 02-22-2011 09:04 AM
Leaking air shocks - New Works Shocks RoadGlide5150 Equipment-RG 0 10-29-2010 04:04 PM
