front end chatter under braking? - Road Glide Forums
post #1 of 6 (permalink) Old 08-13-2012, 07:35 PM Thread Starter
I have an 07 Roadglide and I have noticed a slight chatter in the front end while braking (front brake only). It only happens at lower speeds just before coming to a stop. I can feel it in the bars and in the highway pegs. I have found that if I apply the front brake and cycle the front suspension rapidly I feel a clunk and the bottom of the stroke. I am thinking this is a neck bearing issue but I don't have any of the other tell tale signs of a neck bearing issue.
Anyone else experienced this sort of thing?
junk runner jr is offline
post #2 of 6 (permalink) Old 08-13-2012, 08:15 PM
Could be warped rotors?
post #3 of 6 (permalink) Old 08-13-2012, 08:16 PM Thread Starter
I had thought of that but that would not explain the clunk when cycling the forks.
post #4 of 6 (permalink) Old 08-13-2012, 09:19 PM
Rotor are warp get new rotors
post #5 of 6 (permalink) Old 08-17-2012, 02:41 PM
Check the fall-away of the neck bearings, the nut could be loose as there is a history of this. Adjust as necessary. I experienced this on my 2011 RG.
FL64Pan is offline
post #6 of 6 (permalink) Old 08-17-2012, 03:19 PM
Rowdy's Avatar
I would check both the bearing to make sure it is correct, and move on to the rotors. It sounds like you have at least one warped one. I have had that issue on both my SG, and on my RG.
Rowdy
Rowdy is offline
Horrible Front-end Dive When Braking GARIDER Suspensions 19 11-11-2016 09:23 AM
ABS kicks in under light braking cypress Troubleshooting for Road Glides 8 07-07-2012 07:28 PM
Brake chatter on 21" wheel watsondog Tech Area 9 07-22-2011 01:23 AM
CB Chatter -- Educate me. BDMastiff *General Road Glide Discussions/Pictures 26 05-27-2011 08:28 PM
