05 Model RGs - Road Glide Forums
post #1 of 6 (permalink) Old 08-30-2012, 09:35 PM Thread Starter
05 Model RGs
I understand that the 2005 touring bikes have a cartrige-style front suspension, but I'm not so sure about my 2005. I installed some HHI trees and a 23" wheel. The installation process didn't require that I take apart the forks themselves, just take the caps off and screw on the extensions, so I didn't get to see the internals.
Recently, I tried to drain the left fork, and there was no oil. I was told this was normal because of the cartrige style forks.
The front end seems a little squishy, and makes some noise in the left fork (like a spring compressing in a tube).
Do the cartrige style forks require oil in both sides? How would I know if the internals were changed?
tonka9532 is offline
post #2 of 6 (permalink) Old 08-31-2012, 04:54 AM
FrankieB's Avatar
Tracy's 05 only had a cartidge in one side, if i remember correctly it was in the left fork. You should have gotten atleast some oil out of them.
06 RK
11 RGU
FrankieB is offline
post #3 of 6 (permalink) Old 08-31-2012, 09:07 AM
04's have cartridge on 1 side only, springs on the other. Get progressive monotubes and be happy.
2013 FLTRU 2010 2into1 decatted headpipe, nightstick, fuelpak, big sucker, madstad, wards parts werkes fans, j&m 7.25 front, j&m 5.25 rear, 40.4hogtunes, kuryakin led driving lights/turn signals, led caliper driving lights, brightass tail light, race tech springs and gold valve emulators, progressive 412s, kw stretch heritage bars, enforcer wheels
amfyoyo is offline
post #4 of 6 (permalink) Old 08-31-2012, 09:45 AM
rrs49's Avatar
+1 on 05 having one cartridge and one spring. I have replaced my setup with Progressive Monotubes, a dual strut setup that vastly improves handling, as well as front end dive. You can find them online at prices in the $300 range. Installation does require taking forks apart but it is a solid investment.
rrs49 is offline
post #5 of 6 (permalink) Old 08-31-2012, 06:35 PM Thread Starter
I need to look into the Progressive Monotubes. I hear good things about them.
If I buy the lowered monotubes, is there an option to lower them even more if I don't like the height? I'd like the bike as low as possible.
Also, can I get travel limiters if I have the monotubes? My current travel limiter is my fender and triple tree, and that sucks...
post #6 of 6 (permalink) Old 08-31-2012, 09:21 PM
FrankieB's Avatar
You can drop the lowered montubes to approximately 2". You will have to use the stock and the supplied top out spring.
06 RK
11 RGU
FrankieB is offline
Later model fork legs on older model? Songman Suspensions 9 04-16-2017 09:48 AM
2016 RGS or 2017 RGS? PEZRACER *General Road Glide Discussions/Pictures 11 09-01-2016 03:14 PM
Are the handlebars on the 2015 CVO model the same bars that come on the RG and RGS? Berms *General Road Glide Discussions/Pictures 14 11-29-2014 03:39 PM
Lower Fairing doors - 58681-05 & 58679-05 akawolf Sold 1 03-10-2013 12:25 PM
Want the Painted inner fairing, what year and model? RoadGlideBlues *General Road Glide Discussions/Pictures 9 10-23-2009 08:54 AM
