Compressor location - Road Glide Forums
post #1 of 5 (permalink) Old 09-07-2012, 11:38 AM Thread Starter
Compressor location
I know that it may have been discussed before but I do thank you for any input and or threads that you can give me.
Where to mount the air compressor for rear air ride on a 2011 Road Glide SE Ultra. It does have ABS. Any suggestions would be helpful...
thanks
E9 Turbo
http://choppedbaggers.com/forums/sho...m-paint/page14
Just wanted to post this all white road glide
e9turbo is offline
post #2 of 5 (permalink) Old 09-07-2012, 12:02 PM
FrankieB's Avatar
thanks
E9 Turbo
make a bracket and mount it in your fairing.
06 RK
11 RGU
FrankieB is offline
post #3 of 5 (permalink) Old 09-07-2012, 03:26 PM Thread Starter
thanks Franky, I did want to see where people are putting besides the fairing minimize the air hose length. If you can fab up a section under the seat.
Thanks again
E9 turbo
e9turbo is offline
post #4 of 5 (permalink) Old 09-07-2012, 04:05 PM
faststan's Avatar
Mine had to go in the fairing due to ABS. It appears to be the cleanest location. If you put it in a saddlebag you will have to have a way to disconnect it when you remove a saddlebag. I don't think there is enough room under the seat or gas tank. You could possibly put it in the tour pack but if you ever decide to make it removable you will have to relocate it again. Good luck.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #5 of 5 (permalink) Old 09-13-2012, 10:22 AM
Sikk1's Avatar
My compressor is mounted in my fairing-I have Arnott the bracket that came with it you can drill 2 holes in your radio mount and use a couple spacers and bolts and it fits there fine, the relay is on right side under ABS
Sikk1 is offline
Hotel Issues - location location location DreamRider ARCHIVES-SWII LeClaire, IA 29 07-11-2012 01:40 PM
Road Zeppelin Air Compressor BGD_HOG Seating: seats, backrests 2 03-16-2012 03:26 PM
Progressive compressor Mcrider996 Suspensions 3 02-16-2012 06:56 PM
Bought air shocks. Need compressor . Help!!! 19Cobra96 Aftermarket Accessories 1 11-01-2011 04:34 AM
Kool Air Compressor Gadjet jimmyray11349 *General Road Glide Discussions/Pictures 3 05-23-2011 05:03 AM
