Progressive chassis stabilizer - Road Glide Forums
post #1 of 22 (permalink) Old 09-10-2012, 08:51 PM Thread Starter
The Stone King's Avatar
Anyone tried one of these yet? Curious on any feed back if you have
http://www.baggersmag.com/tech/1203_..._newer_models/
1203-hrbp-01-o+progressive-suspension-touring-link-chassis-stabilizer-for-09-and-newer-touring-m.jpg
Too much to list just ask lol
The Stone King is offline
post #2 of 22 (permalink) Old 09-11-2012, 04:52 AM
FrankieB's Avatar
Attachment 14890
Not tried one myself but talking to others, all the bolt on stabilizers work. If this is for an 09 and up bike you shouldn't need one.
06 RK
11 RGU
FrankieB is offline
post #3 of 22 (permalink) Old 09-11-2012, 02:05 PM
Q-Hog's Avatar
I brought one from Phat Performance a few years ago & installed it on my RG. The tension bar broke around 3000 miles later. I called up Phat Perf. & they charged me for another bar. Which sucked..
Q-Hog is offline
post #4 of 22 (permalink) Old 09-13-2012, 10:39 AM
teejay's Avatar
I installed one on my 2001 and immediately noticed the improvement. Make sure you use blue Loctite for the through bolts at the end of the link. I did when replacing the bolt that went MIA.
tj
teejay is offline
post #5 of 22 (permalink) Old 09-13-2012, 02:58 PM
b104396's Avatar
Frankie could you elaborate why not needed on 09 and up. I'm assuming due to frame upgrade. I've been thinking about one of these for my 11 RGU. Cornering with anything other than a smooth surface the front end just not feel solid. Maybe monotubes a better option. Comments?
2011 103" RGU Merlot Sunglo V&H Rounds, SERT, Fullsac X Pipe, SE/AC, SE255 cams,Brightass, IPOD Kit, Zumo 660, Hammock, Heritage Bars, Bag Guards, Tire Presssure Monitoring.
b104396 is offline
post #6 of 22 (permalink) Old 09-13-2012, 04:13 PM
RichieRich's Avatar
I ask the same question a couple weeks ago. The frame upgrade is exactly why you an 09 and up bike doesn't need this part.
2013 BBP FLTRX
RichieRich is offline
post #7 of 22 (permalink) Old 09-13-2012, 04:55 PM
tj316's Avatar
well I do not agree , I ride aggressively and on my 2011 at higher speeds and in sweepers my rear end would fill like my tire was going flat , not a huge wobble but loose , I installed True Track and it solved my problem , I am attaching an article I printed and scanned from HDForums by Graham Brown , Graham is a long time rider and very knowledgeable
tj316 is offline
post #8 of 22 (permalink) Old 09-13-2012, 04:56 PM
tj316's Avatar
the rest of the article
tj316 is offline
post #9 of 22 (permalink) Old 09-13-2012, 05:11 PM
tj316's Avatar
one more thing , Graham also lookd at all the stabilizers and felt True Track performed the best , you can go to hdforums and search this thread and read more if you like
tj316 is offline
post #10 of 22 (permalink) Old 09-13-2012, 06:13 PM
RichieRich's Avatar
Well, I stand corrected. If you are going to bend a corner on your RG they by all means get the part. Price is fair and it seems that install is straight forward. I just doubt that I would notice a difference given my style of riding. Less that spirited. lol
2013 BBP FLTRX
chassis stabilizer Hematite Suspensions 29 02-28-2016 12:45 AM
Progressive Suspension Touring Link Chassis Stabiliizer Q-Hog Parts for Sale 6 05-04-2015 08:39 PM
S&S T-144" now available for OE chassis fitment. Hillsidecycle.com Engine Related 23 10-04-2014 09:19 AM
Progressive stabilizer link Ugly Shawn Suspensions 1 09-20-2013 04:20 PM
Rear Stabilizer? Frodoe Equipment-RG 7 12-08-2010 09:51 PM
