Ricor Intimindators and Fork Question - Road Glide Forums
post #1 of 9 (permalink) Old 09-18-2012, 12:44 PM Thread Starter
I have a 2009 CVO RG and am in the process of installing a set of Ricor Intimindators. I'm having some trouble with fork oil level for my forks. The install instructions indicate:
• 1/2 quart of Amsoil 5W 39-41mm
• 1/3 quart of Amsoil 10w 49mm
Which forks do I have (39-41mm or 49mm) and from your experience are the quoted oil levels accurate? I weigh 240 and ride somewhat aggressively.
I put 16 oz of Amsoil 5w in each leg and have the bike pretty much put back together, but holding off completing the project until I hear that I didn't screw up. BTW: I spoke with Brian. His recommendations for oil volume are that the level should be 6" from the top of the fork tube when compressed. I didn't do this - I went with the 1/2 quart per leg. Brian doesn't know how many ounces are needed to reach the 6" mark.
Any help is appreciated. Thanks much.
Vinchenz is offline
post #2 of 9 (permalink) Old 09-18-2012, 01:41 PM
tj316's Avatar
you have 41mm , 16oz should be ok , when I ran them 12oz put me at the 6" mark
tj316 is offline
post #3 of 9 (permalink) Old 09-18-2012, 02:54 PM Thread Starter
TJ316,
Based on your experience, I think I'll drain a few ounces from each leg and try that. Thanks for the reply.
Vinchenz is offline
post #4 of 9 (permalink) Old 03-10-2013, 10:23 PM
How did it turn out. I'm putting the RICORs in soon, with race tech springs.
NYSport is offline
post #5 of 9 (permalink) Old 05-06-2013, 05:20 PM
???? Updates ????
2013 Harley Davidson Road Glide Custom Big Blue Pearl
Arlen Ness Inverted Big Sucker Deep Cut Chrome Aircleaner, FuelMoto Power Vision tuner, Jackpot 2-1-2 header, Jackpot 4" slash up mufflers. And a big ole smile on my face
Papi63 is offline
post #6 of 9 (permalink) Old 05-13-2013, 08:29 PM
Well, I installed the Ricor intimidator and race tech springs. The "nose dive" under braking is noticeably improved. The ride is also much better than stock. I think I'll install Ohlins cartridges when they become available. There is still a lot of room for improvement but for the price it is a great upgrade.
2012 RG CVO
2008 Nightster (sold)
NSDQ
NYSport is offline
post #7 of 9 (permalink) Old 05-13-2013, 08:45 PM
gscojo's Avatar
Oil level and sag adjustment are critical with this setup. Unless you took your forks completely apart and cleaned there is no way of knowing how much oil to put in. You can only go by depth. Sag should be 1/3 of total travel.
When I set mine up they felt harsh. I removed 1/8" from the spacer and the difference was night and day. Also took forks apart completely and couldn't believe how much more crap I got out of the forks than I did by just draining them.
It can be a little trial and error to get them set right, but, once complete they should be good to go for a long time.
'08, 103ci, Kuryakyn TC2 cams, SERT tuned on dyno, HD Premium Oil Cooler, Jackpot slip-ons, Ricor with Racetech springs in forks, Progressive 412's
Road King bars (modified), Heated Grips, Mustang Saddle, Trunk, Lowers with Classic vents, Madstad.
gscojo is offline
post #8 of 9 (permalink) Old 05-13-2013, 09:32 PM
To really do this right you need to add a little more that the recommended amount of oil then use a fork oil height tool to pull out the oil until it gets to the correct height. You can get lucky and add pretty close to the correct amount but the gauge is the best way to do it. Motion Pro has on for about $30. It's also important to work the forks with the oil and get the air out from under the intiminators.
rg_dave is offline
post #9 of 9 (permalink) Old 05-13-2013, 09:33 PM
swede0030's Avatar
There is a great educational thread (hours of good reading)on HD Forums converting 41mm front suspension to ricor intiminators with Racetec springs. I pulled my front off 7 times before my final post #112 in the link below hoping to save other folks some time sorting sag base line, etc. I used the recommended oil quantity from HD shop manual.
http://www.hdforums.com/forum/tourin...rk-better.html
Jim
09 CVO rear, Ricor intiminators, Ohlins 3-3, Blade wheels, Corbin Solo, KW 1 1/4" heritage bars, Zumo 665, Chopped TP,255se cams, Bub 7's, Touring Duals, PCV
2011 RGU
swede0030 is offline
Ricor Rear Shocks Tytanium *General Road Glide Discussions/Pictures 10 10-14-2011 09:26 PM
RICOR shocks and INTIMINATOR roadglide33 Suspensions 2 07-13-2011 02:48 PM
Ohlin, Progressive or Ricor shocks??? roadglide33 Suspensions 6 06-27-2011 12:18 PM
Ricor shocks and Intiminator emulator... roadglide33 Equipment-RG 0 06-22-2011 09:29 PM
RICOR - anyone running intiminators or shocks? Gadgetech Suspensions 6 02-01-2011 11:40 PM
