Avoiding rear tire / fender contact - Road Glide Forums
post #1 of 4 (permalink) Old 09-27-2012, 10:01 AM Thread Starter
SmokinToad's Avatar
I'm on a 09 RG and considering new shocks. I was wondering if anyone knows for sure the shortest fully compressed length shock that can be run. From progressive recommendations I could assume approx. 9.5" but I'm hoping it's lower.
I guess I could remove my stock shocks and lower the jack until tire and fender meet... then measure mount to mount and add 1/2" to 1", but maybe someone here has already done this and can save me an hour of wrenching.
2009 FLTR Mirage Orange
2007 Nightster Silver / Black Denim... SOLD
SmokinToad is offline
post #2 of 4 (permalink) Old 09-27-2012, 12:24 PM
faststan's Avatar
Given the state of today's hiways/roads do you really want to ride a 'hard-tail'? I think anything shorter than 12" shocks will limit the shock rebound and give that type of ride. JMO.
11 FLTRU 103 Red Hot Sunglow
faststan is offline
post #3 of 4 (permalink) Old 09-27-2012, 03:14 PM Thread Starter
SmokinToad's Avatar
Just thinking about it from the other direction to get most travel in a shorter shock.
If max compression is 9.5" then;
a 13" shock with 3.5" max travel
a 12" shock with 2.5" max travel
a 11" shock with 1.5" max travel
The max compression before tire / fender contact + shock travel = Shock length.
From Progressive..
PN...........Length...Compression...Travel... Spring Rate
444-4049.....12.0.......9.26..........2.74.....90-130
444-4058.....12.0.......9.76..........2.24.....115-155
post #4 of 4 (permalink) Old 09-27-2012, 03:31 PM
Sounds like the number you got from progressive is the same number I got from Bitchin Baggers, I'm running 11-3/4 shocks now and they told me I have 2.5 inches of travel, another 1/4 and I'll be touching the tire, so if you add it up, it seems right.
Canadian rear fender to U.S. rear CVO fender mikehall11 Lighting 10 06-05-2013 02:45 PM
For those trying to contact Marty at GAUGELEDMODS TracyB Lighting 2 10-27-2012 09:48 PM
Contact info -AndyM GordonC Dyno Results 0 04-13-2012 06:11 PM
Larry Connell - Please Contact Me PC PaiN *General Road Glide Discussions/Pictures 2 12-15-2011 01:41 PM
