Problem with stock air shocks - Road Glide Forums
post #1 of 14 (permalink) Old 10-06-2012, 07:13 PM Thread Starter
Bluefilhd's Avatar
I'm wondering if anyone else here has come across this. Basically I can't get air into the shocks. Try to pump a bit in with a couple different hand pumps and it just doesn't get air in there and there is plenty of back pressure when pulling the pump off. Maybe my method is flawed but I'm assuming there is no air in there because when I try to let air out I get nothing. Oh yeah, and the wife gives PLENTY of input on how she feel every bump back there. I have pulled the seat and traced the lines and there are no kinks in them. Everything appears to be seated correctly. Short of taking the lines apart and trying to pump air, I'm out of ideas. It's a 2012 RGU and I'm trying to make the dealer my last resort but it may come to that, just trying to save a bit of hassle and I really don't mind wrenching. The only way to learn is to do. But it may end up at the dealer for warranty work if no one here has ideas.
Bluefilhd is offline
post #2 of 14 (permalink) Old 10-06-2012, 07:55 PM
Chester's Avatar
Could the threads on the valve be cross-threaded so that the pump is not going on correctly?
2012 RGU, Ember Red Sunglo,
REMEMBER WHEN SEX WAS SAFE AND MOTORCYCLES WERE DANGEROUS???
Chester is offline
post #3 of 14 (permalink) Old 10-06-2012, 08:02 PM
JacktheBagger's Avatar
what kind of pump are you using ?? you need a "zero loss" I believe its called , ones like the HD pump are the cats meow
JtB
2011 Ultra
JacktheBagger is offline
post #4 of 14 (permalink) Old 10-06-2012, 08:03 PM
Jax
Jax's Avatar
Are you using one of the "clip on" type hand pumps or a screw on. I tried to fill mine with a bicycle pump that clips on and got the same results, backpressure but no flow. I bought the little screw on pump made by Harley specifically for the job and it fills fine. Expensive little pump (like $40) but it really is pretty nice for the job. It has a gauge on it and it does not let air escape when you unscrew it.
Jax is offline
post #5 of 14 (permalink) Old 10-06-2012, 08:44 PM Thread Starter
Bluefilhd's Avatar
I have the little Harley pump. Same result.
Threads on the pump and the valve are perfect and I'm sure I'm not cross threading.
And I've tried a clip on pump as well. All with the same results.
post #6 of 14 (permalink) Old 10-06-2012, 08:50 PM Thread Starter
Bluefilhd's Avatar
Kinda like the lines are plugged or something. Don't know if that's possible but that's what it seems like. Unlikely but I guess we never know.
post #7 of 14 (permalink) Old 10-06-2012, 09:09 PM
tdkkart's Avatar
Sounds like the valve in the bikes connecter isn't getting compressed for some reason, so basically you're only filling the pump hose. Most often this is caused by something screwed up in the pump hose connector, little nib in the center is missing or messed up. It's possible the valve in the connector n the bikee is screwed up, but not likely.
Take the pump back to the dealer and see if you can compare it closely to another one.
tdkkart is offline
post #8 of 14 (permalink) Old 10-06-2012, 09:14 PM
HarleyLance's Avatar
Similar to tdkkart, check to see if the valve on the receiving end of the shocks depresses. Might be stuck, or somehow the pump is not fitting tight enough to depress it.
2010 Road Glide Custom FLTRX Scarlet Red - SE Stage 1 AC, Carriage Works Tornado Slip-on, SE SuperTuner, Jagg Fan Assisted Oil Cooler, 12" Windvest, HD Chrome Saddlebag Guards, Arc Audio MPAK 6
HarleyLance is offline
post #9 of 14 (permalink) Old 10-06-2012, 09:20 PM
qkshift's Avatar
Sounds like your not depressing the valve core you can gat a valve core tool from auto parts and a new core I have seen them bent were you cant get air in also I recomend the harley pump or some other screw on type hand pump
qkshift is offline
post #10 of 14 (permalink) Old 10-06-2012, 09:25 PM Thread Starter
Bluefilhd's Avatar
Valve core appears to be ok but may be the next/ easiest route to go. I do have the Harley pump and use it or at least attempt to use it. Just tried other pumps to see if they did anything. Well maybe I'll try replacing the valve core tomorrow. If not, off to the dealer. Thanks. Still open to more ideas also though.
Police seat air supply from air shocks? Eshaw301 Seating: seats, backrests 4 07-01-2012 06:25 PM
Stock RGU Air Shocks not holding b104396 Troubleshooting for Road Glides 3 07-27-2011 11:04 AM
2010 FLTRX stock seat and air shocks for sale Too Short Classifieds Archive (3 months old+) 17 02-21-2011 10:30 AM
Leaking air shocks - New Works Shocks RoadGlide5150 Equipment-RG 0 10-29-2010 04:04 PM
Done with the stock air shocks connector Aftermarket Accessories 0 05-23-2010 09:37 PM
